PinePhone power issues
Question
I have a UBports Edition, and the phone is having issues staying powered on. It'll run 5-60min then hard power off (on battery or cord or battery+cord). I have to remove from power (including battery) wait 5-15 min "rest period" then usually it'll only turn back on when power plug is inserted without battery. I'm suspecting something with power or heat, modem is a bit warm, would not call it hot. Has ran fine up until ~3 weeks ago (owned since April?).
I can't keep in on long enough to troubleshoot... I'm working on making a SD card image, but have experienced this issue with UBports and Manjaro.
Anyone experiencing? Anyone have suggestions?
(11-16-2020, 02:49 PM)Andrewjneumann Wrote: I have a UBports Edition, and the phone is having issues staying powered on. It'll run 5-60min then hard power off (on battery or cord or battery+cord). I have to remove from power (including battery) wait 5-15 min "rest period" then usually it'll only turn back on when power plug is inserted without battery. I'm suspecting something with power or heat, modem is a bit warm, would not call it hot. Has ran fine up until ~3 weeks ago (owned since April?).
Booted latest Manjaor from SD card and experience the same issue. Makes it maybe 15min before hard power off.
Update: I'm now unable to get booted on battery or cord or battery+cord. Experienced the same issue with Manjaro SD card boot as with UBports. I have reached out to support.
Worked with Pine support, after all the troubleshooting, a simple re-flash of the eMMC seems to have done the trick:" https://wiki.pine64.org/wiki/PinePhone#F..._Jumpdrive . I did have issues with low power usb port not allowing the eMMC to be seen by host os.
  Pinephone software Csanderson0313 3 1,281 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 84,145 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,519 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,153 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,119 02-28-2026, 05:49 PM
Last Post: baptx
  Power up a 2nd core? WhiteHexagon 1 1,388 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,489 12-04-2025, 08:07 AM
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,934 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,520 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,007 11-18-2025, 03:07 PM
