Changed pw in terminal to 'asd' can't log in at phone's home screen now
I should have thought that one through! Ooops!
So my question is about factory resetting. I noticed a 'reset' button on the inside with the battery and the switches, but powering off, press and holding, doesn't seem to reset it back to original with the 123456 pw. Is there a protocol I can follow somewhere I just haven't found? Anyone know?
Are you able to ssh into it?
You can use jumpdrive to mount emmc on a PC over USB
Check out this thread, there it is explained how you can reset your password. Mount your file system (either the SD card or via Jumpdrive) and delete the password hash in the /etc/shadow file as explained (on Ubuntu Touch this file seems to be in /var/lib/extrausers).
(11-30-2020, 01:24 AM)LazyMechTech Wrote: Is there a protocol I can follow somewhere I just haven't found? Anyone know?
Your user password must be numeric.
The only way to login is using a pin code, not actually a password.
The root account can have any password you want, and very recommended to change that if you plan on using SSH on your phone.
  Default password for KDE plasma pine phone Toni 0 8,557 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 4,996 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,476 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,620 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 7,066 09-19-2024, 03:49 AM
Last Post: jennybaso
  PinePhone Boots but only Shows Black Screen with Backlight danyeaw 1 3,234 06-30-2024, 10:18 AM
Last Post: danyeaw
  Looking for the "non-phone" OS wakyct 7 9,503 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,290 03-11-2024, 10:42 PM
Last Post: Emelia525
  Encrypting home directory coderx 1 2,615 02-17-2024, 10:25 PM
Last Post: aular
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,914 01-09-2024, 07:02 PM
Last Post: britelite
