Flashing SC card for Ubuntu Touch
I'm a NOOB. I have an Ubuntu computer and a Windows 10 computer. I have also had a stroke. I have just bought my Pinephone with Manjaro on it, but it has Postmarket OS on it instead. I want to flash my phone, but am not sure how to do it. I followed the following instructions:
Detailed usage instructions
I got the Jumpdrive image on my pinephone saying that it's ready to go but then (point 5) I'm not sure. How do I flash my pinephone? Do I use etcher? Also, which computer is easier, the Ubuntu or the Windows?
Many thanks,
Chris
(11-19-2020, 07:12 AM)thorensjubilee Wrote: Hello,
Many thanks,
Chris
With Ubuntu, just double click on the manjaro image. It will open the built in disk copying program. Be sure to select the sd card and not your harddrive. It will ask you to confirm twice before doing it.
Many thanks,
Chris
Thanks for replying. I have already used the Jumpdrive to flash UB Ports to my Pine phone.
Chris
  install iso from sd card to emmc aular 2 4,203 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,920 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 11,225 06-11-2023, 12:30 AM
Last Post: AndyM
  trouble flashing eMMC TylerBlackberry 3 5,980 04-13-2023, 05:55 AM
  Device Unable To Read MicroSD Card _radv_ 19 20,595 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 5,131 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 7,236 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 4,935 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 9,536 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  Flashing gone wrong erg 9 12,842 05-28-2022, 10:52 AM
Last Post: fxc
