PinePhone won't boot
Hello everyone
I got my "Manjaro Community Edition with Convergence Package" a couple of days ago and tried to set the phone up yesterday.
The first time I tried to boot it, I just removed the battery seal, connected it to USB power and gave it a go with no SIM and no SD inserted. A red LED in the upper left corner of the phone started to light up, but the screen did not do anything. After maybe 15 seconds the red LED went off. I retried several times to power on the phone, but it would just not boot.
I assumed that maybe there is no OS on the internal memory, so I went ahead, downloaded beta1-20201104 of Manjaro Phosh and burned it to the SD with dd.
I then inserted the SD into the PinePhone and tried to start it up several times. All I ever got was the red LED. After maybe 10 attempts to boot the PinePhone, the screen was finally lid and I saw the Manjaro logo alongside a loading animation for about a minute before the device has switched itself off again. I was unable to make it boot ever since. All I ever see is the red LED.
I tried to find my way around the wiki, but couldn't find a useful starting point for my case.
Should I try to have a look at the logs on the SD?
Many thanks for your help in advance.
PD: I am new to Linux. Smile
Perhaps try using Balena Etcher to flash your sd card ?
Good Luck
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Somewhat the same issue here, it gets to the unlock screen, but when I try to unlock it I get a blinking cursor at the top left of the screen. I tried to run the latest Manjaro on SD, but it does the same. Switched to PostmarketOS on SD and that seems to work. But it's kind of strange that the stock OS doesn't even boot....
I received Manjaro Community Edition Pinephone (Convergence Package) just today. The phone won't boot for me either. Very similar symptoms as for @amadeusp81. It tried to boot on the first power-on, but after a minute or so the phone was off. Now all I get is the red led. And in some cases when I try to power it on the screen would turn on (become grayish) for just a second or two. Then it's off again.
I would appreciate any advice now. Should I try to boot from SD? Please, anyone who had the same symptoms and have a fix, let us know.
Here is the solution which worked for me:
1. Install https://www.balena.io/etcher/
2. Flash https://github.com/dreemurrs-embedded/Ju...one.img.xz to an SD card. Mine was 64GB.
3. Remove the battery. Insert the SD card. Keep the battery removed.
4. Plug the PinePhone through the (official) USB cord to the computer. The image boots in 2 seconds and "Jumpdrive is running" is seen.
5. Download https://osdn.net/projects/manjaro-arm/st...104.img.xz
6. Flush the Phosh image to the eMMC USB Device 31.3GB. The other one (microSD USB Device) was seen too, be carefull. Flushing speed was 14MB/s.
7. Insert the battery and power on the device. Now it works as expected.
Also, have a loot at the similar thread here: https://forum.pine64.org/showthread.php?tid=11993
Hi cong-v,
Thank you for this procedure. I followed it an successfully updated the OS on the eMMC to the latest version of Manjaro. The issue remains the same after this. I get to the lockscreen, but it repeatingly enters a state with a cursor flashing in the top left corner. I've follow the same procedure but then with postmarketOS and this works as expected. It looks like there maybe some phones that are incompatible with the current version of Manjaro?
Hello everyone,
https://gitlab.manjaro.org/manjaro-arm/i.../issues/52
^ It looks to me that the Manjaro with Phosh distribution has not been stabilized yet to be somehow usable at all. Please correct me, if I'm wrong.
Today I installed UBPorts and that works really fine. Just flashed the latest Manjaro Beta 2 and it still has the same issue.
UBPorts works really nice actually (except that I'm not able to make calls though... texting works fine). But it really shows that the hardware is quite nice.
Hmmm.... now Jumpdrive is not working anymore. Anybody any thoughts on that?
(11-10-2020, 10:39 AM)martijnv Wrote: Hmmm.... now Jumpdrive is not working anymore. Anybody any thoughts on that?
How exactly is it failing? Blank screen on your PinePhone when you boot it? Can't connect your PinePhone to your PC?
Try reflashing the SD card you have installed JumpDrive on with a fresh install?
  Pinephone visibly losing power while plugged in Hiraghm 10 10,393 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,182 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 89,396 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,282 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,280 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,880 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,582 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,208 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,604 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,079 10-21-2025, 12:12 PM
Last Post: Richy_T
