Keyboard settings not saved on reboot
Every time I start up the pbp the keyboard switches back to the default UK English, when I want US English. I have to manually switch it to US everytime. How I can make it save the setting? And yes, I hit apply.
(10-30-2020, 10:47 AM)motezart Wrote: Every time I start up the pbp the keyboard switches back to the default UK English, when I want US English. I have to manually switch it to US everytime. How I can make it save the setting? And yes, I hit apply.
When you are in that settings page, after selecting us eng then delete the uk eng. I believe that should fix it. Let me know if that works.
Hey, how do I delete it? I've right clicked. I can't see any way to do it.
Sorry I didn't know you were using manjaro, mine came with Debian and there is an option to remove the uk keyboard. When you first set up you pb did  you pick uk by accident? I just replaced my factory Debian with Manjaro as that is what comes with them now and set my keyboard during the set up. Unless someone chimes in, when I get home from work I'll look to see how to do this in manjaro. I found this online, https://low-orbit.net/arch-linux-how-to-...ard-layout Manjaro is arch based so this may work.
It was set to UK out of the box.  I don't think I set it to UK when I did initial setup. It still isn't saving the settings after power down.
After you select your desired keyboard, click on the one you don't want and the delete button should now be active. I also noticed that if I have 2 or more keyboard layouts it allows you to move them up or down in the list, I wonder if when it boots it looks for the first one in the list to default to. Try moving the us to the top of list and reboot to see if it sticks before you delete the uk one.
Edit: After selecting a new keyboard and moving it to the top of the list I can confirm that the layout that is at the top of the list will be persistent across reboots. So I would add you us keyboard and move it to the top and you'll be good to go.
in system settings go to hardware - input device, then the Layouts tab and try switching it from there. It worked for me.
  Keyboard issue j0rs 3 5,245 01-20-2025, 07:03 AM
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,645 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 3,917 11-25-2024, 03:42 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,767 01-16-2024, 09:17 AM
Last Post: jbradley419
  Dead Pinebook Pro Keyboard Keys calinb 2 4,244 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 2,905 07-20-2023, 11:06 PM
Last Post: papable
  ISO keyboard Pinebook pro for sale tgrauss 3 7,204 11-01-2022, 04:45 AM
Last Post: tgrauss
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,414 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,218 09-14-2022, 03:56 AM
Last Post: Carl
  Selling PineBook PRO with ISO Keyboard + NVME firefox-58 27 39,073 04-08-2022, 06:23 AM
Last Post: firefox-58
