Arch, Plasma desktop and wayland
#21
5.20.1 solved all of the problems I had.
(10-21-2020, 01:09 AM)peperjohnny Wrote: 5.20.1 solved all of the problems I had.
It fixed all the glitchiness for me as well, however, now my on-screen keyboard isn't working. It shows the popup for it being disabled and enabled when I put the tab on and off the keyboard case but when I tap on any text input field I get nothing. Anyone else having the same issue?
Same here...  Can't seem to force it up at all.
David
de KL7JKC
The problem I have with the OSK is that it only shows up for Qt programs. So Vivaldi (presumably Chrome, too) doesn't show it.
(10-23-2020, 10:08 AM)wd5gnr Wrote: The problem I have with the OSK is that it only shows up for Qt programs. So Vivaldi (presumably Chrome, too) doesn't show it.
Interesting. I can't get it to pop up for anything including qt apps like konsole and dolphin.
Latest updates have borked things. Now when I boot I can still see the console bout messages and a cursor on a black screen.
probably a stupid question, but how do I get to a commandline while in plasma?
Because the software center is empty and I see no terminal anywhere.
And alt-f2 doesn't work either.
Any tips?
when I do alt-f2 you can click on "get Xfe terminal
then discover says "couldn't open appstream://xfce4-terminal.desktop"
For the rest it looks and works fabulous. Lot better than the posh I tried before.
(11-15-2020, 04:01 AM)hanscees Wrote: probably a stupid question, but how do I get to a commandline while in plasma?
Any tips?
I have Terminal under Menu/Applications/System/.
Ctl-Alt-F3 through F6 gets me a virtual terminal (in portrait mode)
Ctl-Alt-F2 goes back to the GUI.
Ctl-Alt-F1 is active but stuck at a 'splash' screen.
I have not done the latest update due to the above post.  Waiting for more responses/solutions.
Everything else is pretty good except no virtual keyboard.   Cool
de KL7JKC
Any tips?
Everything else is pretty good.   Cool
Thanks!
I got it fixed by dropping out of plasma using
cnt-alt-shift-del
then installed konsole and packagekit-qt5 using Pac-Man
sudo pacman -S konsole packagekit-qt5
but your solution is a lot better.
Also, I just installed from scratch and all works well, no glitches. Got the latest image of course and so on
Now using
discover 5.20.3
kde frameworks 5.75.0
qt 5.15.1
Any tips?
Thanks!
cnt-alt-shift-del
Now using
discover 5.20.3
qt 5.15.1
I was never able to get Wifi to work in the scratch image.  I always had to install the Phosh, then install Plasma and disable Phosh.  Very clumsy, and I expect there is still overhead in the OS that I would like to get rid of, but not enough time to sort out the issues.
Thanks for the update on your success!
Smile
de KL7JKC
  How to improve KDE plasma ? louson 2 3,002 05-08-2025, 05:02 PM
  How to install Plasma Mobile in Archlinux Surehand53 14 23,557 02-28-2024, 07:07 AM
Last Post: aular
  Plasma Update broken? Corkonian 0 2,537 11-03-2023, 07:40 AM
Last Post: Corkonian
  Arch Linux (danctnix) virtual keyboard layout change cudo 0 2,745 09-27-2023, 12:19 PM
Last Post: cudo
  Favourite desktop environment discussion FortunateFowl 6 7,777 09-02-2023, 07:38 AM
Last Post: lllll
  Plasma Mobile configuration Surehand53 0 4,265 07-05-2023, 03:29 PM
Last Post: Surehand53
  Download new plasma widgets error Corconegre 1 3,025 06-26-2023, 05:20 AM
Last Post: dachalife
  No desktop after latest updates (Jun 16, 2023) rqkeating 5 5,953 06-21-2023, 04:16 PM
Last Post: rqkeating
  Arch Linux ARM on PineTab 1 Danct12 25 49,352 06-10-2023, 05:33 PM
Last Post: fxc
Video Does DactNix Arch Linux support my use case? BlueGalaxy 22 23,847 05-18-2023, 03:45 AM
