Best Gnome distro for PBP?
I was wondering if someone had the opportunity try the gnome desktop environment on other distros that could give a brief comparison to Manjaro Gnome.
It runs well enough but isn't buttery smooth all the time. If they are just as comparable as Manjaro, I will try the deepin desktop environment. Someone was able to successfully compile it another thread and had good results.
Well, I kind of had to roll my own, but the new Armbian builds work very well with GNOME desktop environment installed.
Here's a tweet showcasing what I did.
Here are the steps I took:
# Update Packages sudo apt update sudo apt upgrade # Install gnome basic packages (be sure to switch to gdm3 when prompted) sudo apt install gnome-session gdm3 # Install gnome extra packages sudo apt install gnome-terminal gnome-control-center gnome-tweaks nautilus gedit gnome-screenshot gnome-software # Create home directory folders mkdir ~/Desktop ~/Downloads ~/Pictures ~/Public ~/Videos ~/Documents ~/Music ~/Templates # Reboot, click the gear on the login screen, and choose Gnome on Xorg
Two things I am currently not able to figure out are suspend and enabling wayland.
Edit: I fixed Wayland on my own groovy build with gnome which you can download here: https://www.ironrobin.net/clover/droppy/...ro/armbian
After building my own manjaro gnome image, i am even more confident that the best gnome experience is still armbian focal. I am still having an issue getting gdm3 to start wayland, while manjaro doesnt seem to share this issue. gnome animations are way smoother on x11 armbian however. but it would be really nice to get wayland to work. this appears to be my bug: https://github.com/systemd/systemd/issues/5247
edit: build my own armbian gnome images and got wayland working out of the box! https://www.ironrobin.net/clover/droppy/...ro/armbian
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,275 08-09-2025, 06:53 AM
Last Post: Sb2024
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 7,735 08-21-2022, 12:00 PM
Last Post: u974615
  which distro + DE are you using these days on the Pinebook Pro? halogen 26 46,113 02-23-2022, 07:55 AM
Last Post: user18130814200115
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 3,736 02-18-2022, 12:59 PM
Last Post: ImmyChan
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 4,562 07-13-2021, 10:37 PM
Last Post: pjsf
  Recommended distro? djhnsn 2 7,378 05-14-2021, 02:03 PM
Last Post: slyecho
  Live distro GloriousCoffee 1 5,495 01-16-2021, 03:47 PM
Rainbow Armbian Groovy/Bullseye with Gnome clover 10 20,903 12-27-2020, 04:10 PM
Last Post: bus-error
Information How to make the Manjaro Gnome image update TDC_PBP 2 7,056 07-13-2020, 02:24 PM
Last Post: TDC_PBP
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 45,693 07-02-2020, 11:04 AM
Last Post: mlentink
