Did the pinephone 1.2a board undergo certifications?
Or was certification of the 1.2 boards "good enough"?
(10-10-2020, 12:00 PM)desca Wrote: Or was certification of the 1.2 boards "good enough"?
PCB v1.2a is identical to v1.2 with two components removed replaced. There was no need for the device to be re-certified again.
Just out of curiosity, do you know what makes a change significant enough to trigger recertification?
Any change to major components (ICs, transformers, antenna design) that leads to different functioning or specifications. There's a bit of info on this page for a company that helps clients certify (there is a section or two specifically mentioning licensed devices like mobile phones):
https://www.cetecom.com/en/certification...ification/
it doesn't get happy
it doesn't get sad
it just runs programs
Thank you. That makes sense to me that the FCC, at least, may be satisfied as long as you aren’t doing anything to the radio or maybe likely interference sources.
  Pinephone + Keyboard for sale, little use ruemoo 17 12,898 08-04-2026, 06:27 PM
Last Post: greebleshaver
  Pinephone - broken power button rorus 14 24,491 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,874 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 20,728 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 8,196 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,506 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,716 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 6,182 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,461 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,271 03-25-2025, 08:51 PM
