noob with non booting rock64 4g
Hi
ive read other posts and im trying to establish if my board has a HW issue.
ive flashed some raspberry pi (32 bit) previously so i believe im flashing my sd card ok.
i gave a green led on longside the power connector
i have a solid red and a while led on by the gpio pins.
the activity led on the nic port (on the usb side of the port) is solid amber regardless of cable in or out
the other nic led is always off.
the power button longside the white led turns all but the green led off.
there is no hdmi output .
what do i do next to determine if its a brick or not
What image are you trying to boot?
Hi
the last image i tried was Armbian_20.08.1_Rock64_bionic_current_5.8.6_desktop
regards
Can't be certain but I think the Rock64 struggles with newer versions of Linux 5x. I'm using the following version
____ ___ ____ _ ____ _ _
| _ \ / _ \ / ___| |/ / /_ | || |
| |_) | | | | | | ' / '_ \| || |_
| _ <| |_| | |___| . \ (_) |__ _|
|_| \_\\___/ \____|_|\_\___/ |_|
Welcome to Debian Buster with Armbian Linux 4.4.192-rockchip64
System load: 0.01 0.02 0.00 Up time: 12 days
Memory usage: 14 % of 3988MB IP: 192.168.0.206
CPU temp: 47°C
Usage of /: 7% of 58G
[ General system configuration (beta): armbian-config ]
See if you grab the above version as I can confirm it works.
IIRC i never managed to boot Buster in mainline, however it booted Focal with GUI. 5.8 6.
(10-11-2020, 06:36 PM)Rocklobster Wrote: Can't be certain but I think the Rock64 struggles with newer versions of Linux 5x. I'm using the following version
CPU temp:      47°C
thanks
more of the same im afraid :-)
the lack of output from hdmi doesn't help.
CPU temp:      47°C
thanks
So connected up to HDMI you are seeing nothing. Make sure you have a good quality HDMI cable connected to the monitor and the board before you power up the Rock64
The only other thing to check I can think of is a bad SD card or a flaky power supply. Try substituting both and see if that helps.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,313 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 25,461 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,267 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 16,680 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,113 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 8,865 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 9,978 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,212 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,348 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,447 10-07-2022, 07:50 PM
Last Post: rookie_267
