installing vpn
Hi all,
I am using a Swedish vpn named mullvad and their debian package is for amd64. As you know, the Pinephone runs on arm64 and after "dpkg --add-architecture amd64" I am still left with an unsatisfied dependency: iputils-ping. Now, I stopped myself just short of installing it since it removes inetutils-ping, mobian-base, mobian-phone-base and mobian-phosh just to name a few. Is this a dead end and should I go for installing open vpn and adding a config file from my vpn in there instead? What method do you guys use to run your vpn on the Pinephone?
Appriciate any tips or advice.
Forget "dpkg --add-architecture amd64" - even if you do get it to install everything the binaries are still the wrong architecture to run. You can ask mullvad to build arm64 packages - you might be lucky! If you can connect to them with openvpn and a config file then that's probably your best bet. I use wireguard between mobile devices and my home network - not tried it on the PinePhone yet, and not sure many commercial VPN providers support it.
Yes, two minutes before your post I went ahead with the -add--architecture route and as you said, it didnt turn out well Cool . Will reflash and go down the open vpn route instead!
I managed to solve it with the help of this guide https://wiki.mobian-project.org/doku.php?id=security together with another one from my vpn provider. I now have a working vpn on the pinephone!   Smile
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,444 01-07-2023, 09:36 AM
Last Post: dcarvil
  ARM Microsoft Teams-problems installing eaglebeckley 15 27,720 01-14-2022, 01:59 AM
Last Post: Tazdevl
  Installing Mobian --> "Resizing file system" forever Anna 13 25,144 09-09-2021, 04:26 AM
Last Post: spaetz
  Installing and tweaking Chromium on Mobian and Arch C0ffeeFreak 19 35,875 03-11-2021, 09:24 AM
Last Post: C0ffeeFreak
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 18,662 03-05-2021, 02:33 AM
Last Post: Anna
  Installing chromium browser? Zebulon Walton 12 31,131 02-09-2021, 12:33 PM
  Installing applicatons via command line Zebulon Walton 2 5,330 12-01-2020, 11:24 AM
