Play along - create a PinePhone keyboard
(09-15-2020, 08:40 PM)SwordfishII Wrote: @Luke didn't see any keyboard news in the Sep news release. Last update was 3 prototypes being examined, any updates?
;-) ha ha
No, no updates I'm afraid - I've been rather busy in the month of August, so I may have missed an internal communication re. this particular topic.
I'll revisit this in November for sure.
Awesome, thank you. The keyboard was the tipping (err typing) point for my purchase. Will probably buy at least one more phone after it releases and keyboard to go with both.
(09-17-2020, 05:59 PM)Luke Wrote: No, no updates
q.e.d.
If @Luke are busy, meybe other developer write some information in this forum? What do you like about our ideas, we would prefer if we had a choice. Can the keys on the outside of the keyboard be? Or will there be a mouse, trackpad etc.?
The TOHKBD layout seems absolutely awesome, I'd totally buy one. It seems that these guys really tought the issue of a mobile keyboard through, instead of blindly copying the PC layout with some minor changes. Especially the navigation block and the layout of modifier keys seems very promising. For example you can easily press combinations like alt+arrow, ctrl+end etc!
(09-14-2020, 02:22 PM)tigerforce Wrote:
(09-14-2020, 09:59 AM)x0r Wrote:
(09-13-2020, 04:26 PM)tigerforce Wrote: Here is a picture of the Aigo P8880E UMPC which was released in 2009
Similar construction to https://en.wikipedia.org/wiki/OQO
But stil 4 in vertical, why not 5 or 6 (similar in normal keyboard)? Sad
still many space in main enclosure.
I agree. Something like the keyboard of GPD Win might be good. It has 5 rows and common symbols don't need the Fn key. I just hate the Fn key being at the left most position. Should switch Ctrl and Fn.
[Image: GPD_Win.jpg]
I think a keyboard more like the gemini pda would be much better for typing on https://www.www3.planetcom.co.uk/gemini-pda
https://www.ti.com/product/TCA8424
https://www.ti.com/lit/ds/symlink/tca8418.pdf
https://www.sprintek.com/en/products/key...px?ad=bing
Will we theoretically be able to design a keyboard with this component? I wish I could just get one I can insert onto a breadboard but these i2c devices seem to only be for PCB boards which means that I would need a development board for it. Once I got that I can test a circuit setup on the ATmega328PB and/or on a Raspberry Pi.
Look up dead bug prototyping - it's rarely pretty but usually works. Did you pick that one because it already has a kernel driver, or is that just good luck?
mobian@mobian:~$ zgrep TCA8418 /proc/config.gz
# CONFIG_KEYBOARD_TCA8418 is not set
(10-05-2020, 07:34 AM)wibble Wrote: Look up dead bug prototyping - it's rarely pretty but usually works. Did you pick that one because it already has a kernel driver, or is that just good luck?
So the TCA8418 is somewhat supported on the kernel level? That means that it would be the appropriate component to use.
It would appear so - see kernel source and docs covering the devicetree entries:
drivers/input/keyboard/tca8418_keypad.c
Documentation/devicetree/bindings/input/tca8418_keypad.txt
Documentation/devicetree/bindings/input/matrix-keymap.txt
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 4 6,279 11-09-2026, 10:04 PM
Last Post: noahclark
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,892 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,506 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,630 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 28,130 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,743 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,584 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,684 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,573 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,401 07-04-2024, 05:40 AM
