Phosh and Plasma together
Hi, got my PmOS phone today, it's working better than I expected, quite happy. but I want to switch back and forth between Phosh and Plasma. If I install postmarket-ui-plasma-mobile are there more steps to make that work? Are there extra steps to make it work as with an average distro on a laptop or pc, with a session menu at login? Or will installing that break something?
Thanks, happily posted from my PmOS CE phone
(09-26-2020, 05:42 PM)stozi Wrote: Hi, got my PmOS phone today, it's working better than I expected, quite happy. but I want to switch back and forth between Phosh and Plasma. If I install postmarket-ui-plasma-mobile are there more steps to make that work? Are there extra steps to make it work as with an average distro on a laptop or pc, with a session menu at login? Or will installing that break something?
There is a 13 images distro you can flash to a SDHC card which allows you to play around for years to come... Confused
Yes, that is an option, but I'm a fan of the PmOS design philosophy, would rather have the one install with two UI options as is common with desktop linux. Interested whether it's feasible on the Pinephone.
I guess you can check which packages each installs, and install them. You'll also need to check which services and configs are mutually exclusive and script a way to swap between them. The one that stands out is modem access via ofono for plasma vs. ModemManager for phosh, but there may be others.
(09-29-2020, 05:17 AM)wibble Wrote: I guess you can check which packages each installs, and install them. You'll also need to check which services and configs are mutually exclusive and script a way to swap between them. The one that stands out is modem access via ofono for plasma vs. ModemManager for phosh, but there may be others.
Thanks, interesting point. Would be nice to switch between UIs and, e.g., have the same tabs, plugins, and settings in firefox. I wonder if anyone is trying this already.
I used to have a shared home partition on the openmoko, with a root partition for each OS flavour and a menu in uboot to pick which one to use. On the pinephone uboot doesn't support the screen (yet?) but perhaps p-boot can do something similar? For now it seems like your itch to scratch.
  [Phosh] : Nheko and gnome-keyring freelectro 1 2,702 12-17-2024, 04:46 PM
Last Post: zeb11
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,531 11-18-2024, 02:23 AM
Last Post: linmob
  Fresh install pmos+phosh does not boot user641 1 3,700 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,736 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 13,036 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,195 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  pmos/phosh edge update and audio disappears robthebold 9 14,753 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 3,606 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,296 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 14,653 02-03-2022, 09:14 PM
Last Post: parry
