Install Anbox on Manjaro plasma-mobile help
I tried to install anbox on the plasma mobile version of manjaro.
I did sudo pacman -S anbox anbox-image and then started the anbox container with
sudo systemctl start anbox-container-manager
but it keep crashing on startup.
Do anyone know what could be the problem?
In the phosh version it came already preinstalled and it work fine so something should be missing on the plasma-mobile version
maybe some env vars?
Regards!
Last I saw, currently the Manjaro Arm kernel does not include the required ashmem and binder modules. Without these, Anbox won't run.
(09-22-2020, 07:38 AM)tophneal Wrote: Last I saw, currently the Manjaro Arm kernel does not include the required ashmem and binder modules. Without these, Anbox won't run.
It should be included now, because alpha3 and alpha4 with phosh came with anbox preinstalled and works fine...
(09-22-2020, 08:22 AM)paju1986 Wrote: It should be included now, because alpha3 and alpha4 with phosh came with anbox preinstalled and works fine...
good to know! i missed that.
I presume starting through terminal doesn't give any good output?
yes, this is error running it from terminal
[manjaro@manjaro-arm ~]$ anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
[ 2020-09-23 12:25:57] [daemon.cpp:61@Run] [org.freedesktop.DBus.Error.ServiceUnknown] The name org.anbox was not provided by any .service files
it looks like this is a known issue: https://github.com/anbox/anbox/issues/1586
I'm trying to boot my pinetab back up into manjaro so i can try recreating this.
I got it running!!! now to toy with it!! Smile
I had to set up the env variable DISPLAY=:1 on the terminal and launch from it
[Image: fdroid.jpg]
it seems really crashy on mine, and the input is non-existent. I tried adding Simple Keyboard from F-Droid but it only shows the top row of keys. maybe in time it will be usable. there's only a few Android only apps I need - my bank app, Blink to view the stupid cameras my wife bought, and the software for my Mi Band 5. Google Pay would be nice, but I believe that they disable their app on non-closed platforms, so it's likely a no go.
at any rate, it crashes constantly for me, and it's unusable atm with no input.
(09-24-2020, 04:49 PM)hiimtye Wrote: it seems really crashy on mine, and the input is non-existent. I tried adding Simple Keyboard from F-Droid but it only shows the top row of keys. maybe in time it will be usable. there's only a few Android only apps I need - my bank app, Blink to view the stupid cameras my wife bought, and the software for my Mi Band 5. Google Pay would be nice, but I believe that they disable their app on non-closed platforms, so it's likely a no go.
Yes pretty much all software on the pinephone is very alpha now, including anbox. It will take time to mature but we are seeing good progress
(09-23-2020, 10:01 AM)paju1986 Wrote: I got it running!!! now to toy with it!! :)
Great job!
But would you mind, sharing the exact method you used to get it running? I'm struggling to reproduce your way.
What I tide:
sudo pacman -S anbox anbox-image sudo systemctl start anbox-container-manager env DISPLAY=:1 anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
however, I keep getting the mention error:
[ 2020-11-14 12:25:43] [daemon.cpp:61@Run] [org.freedesktop.DBus.Error.ServiceUnknown] The name org.anbox was not provided by any .service files
I'd really appreciate any tip/Help to resolve this error.
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 22,452 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,313 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,716 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 3,487 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,779 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,379 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,836 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,858 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 3,457 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 3,585 02-09-2023, 08:17 AM
