Is there a VOIP client compatible with aarch64?
I've tried installing several VOIP clients. So far all are incompatible with aarch64. Is there any available?
A working VoiP-Client or any other messanger client on arm64 is like searching for water in the desert.....
The issue has been raised with the Signal Community for instance, thread is here --> https://community.signalusers.org/t/sign...ne/9001/12
And it was suggested one needs to build from git by themself as described here --> https://www.andreafortuna.org/2019/03/27...-on-linux/
Not the final solution, but a stop-gap measure perhaps... Would be helpful if Pine64 could release sales numbers for PinebookPro and Pinephone so that Developers like Signal  or Matrix are actually seeing that it may be viable to support arm64 with final packages for Electron (arm64), Debian or even Arch...
Maybe not the solution you are looking for. But you can use teams-for-linux, which basically is an electron wrapper around the MS Teams Website and is especially compiled for aarch64.
And you can create shortcuts in Chromium, so you can use several Web versions of the applications each in a separate window. Tried this with Discord, which is working suprisingly well so far
Well, at least signal is available for the pbp at https://forum.pine64.org/showthread.php?tid=9452.
Upstream discussion on building and maybe upstreaming changes needed to make building it easier is at https://github.com/signalapp/Signal-Desktop/issues/3410
(09-18-2020, 02:09 PM)llsf Wrote: Well, at least signal is available for the pbp at https://forum.pine64.org/showthread.php?tid=9452.
Got Skype via Hamsket via Privacyshark. Thanks! I think Privacyshark deserves to be pinned for new users.
  slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) mara 41 71,745 03-18-2023, 04:39 AM
  Signal Desktop Builds for Manjaro aarch64 ninefathom 25 50,828 10-23-2020, 02:19 PM
Last Post: llsf
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 16,762 09-29-2020, 07:55 AM
Last Post: hmuller
  pCloud Client on PBP w/ Manjaro? fbshilli 2 6,426 07-01-2020, 03:04 PM
Last Post: fbshilli
  Pulse Secure Client on Pinebook Pro wwtaylor 0 3,205 05-09-2020, 03:18 PM
Last Post: wwtaylor
  Micro$oft Team$ for aarch64 erchache2000 4 9,546 04-28-2020, 04:34 PM
Last Post: kuleszdl
  Slackware (aarch64) on the Pinebook Pro wowbaggerHU 7 14,889 03-12-2020, 08:29 PM
  Luajit in the AUR, loss of aarch64 support tophneal 0 3,050 02-12-2020, 12:25 PM
  gcc-aarch64-linux-gnu on Debian armhf? chihiro 1 4,581 01-05-2020, 08:23 AM
Last Post: ElektromAn
  Anybody compiled the latest ownCloud client? sobyrne 8 17,320 12-07-2019, 05:14 AM
Last Post: sobyrne
