My Daily QA - 2020-09-11
Be aware, these tests are being executed using an out-of-box testing methodology. All tests are preformed with minimal interaction/setup of devices outside of: OS imaging/updating,  SIM installation, Wifi Configuration,  and Power Cycling the devices.
Results: mobian/2020-09-11-TMobile.html
               mobian/2020-09-11-Verizon.html
Conclusion: OS is not Ready for pinephone to be daily driver.
Notes: Random vibration happens every so often. Firefox took over 30 seconds to load this time. Audio/Video on a YouTube video play back of out of sync. That hasn't happened in a while. Phone defaulted to 3G instead of 4G. That was new. Camera is still laggy, UI drags behind (delayed touch response) Seems like we are regressing a bit on this build.
Yeah,  a step back,  I just tried sept 11 release in PMOS 3g ram phone and was kind a disappointed,
the call out ring tone is a very occasional little beep instead of the ring it used to have.
The other phone rings for minutes before you even hear the first little beep.
I am using my older Brave Heart as a daily driver with a release from September 5 or 6,  even though it is set to auto-update it still has the almost instant ring-tone on the handset indicating that the out-going call is in progress.
Multitasking is very limited. If 4 apps are opened at the same time, the phone freezes
  2020-11-13 Image status. Gribouille 45 68,525 11-14-2021, 12:44 AM
Last Post: Gribouille
  Status update 2020-12-15 a-wai 33 65,525 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 12,356 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 39,752 12-31-2020, 09:51 AM
Last Post: HLing
  Status update 2020-11-15 a-wai 17 28,833 12-05-2020, 05:58 PM
Last Post: bcnaz
  Status update 2020-09-05 a-wai 26 49,821 10-12-2020, 01:50 PM
Last Post: dukla2000
  Status update 2020-10-05 a-wai 8 15,512 10-08-2020, 03:20 AM
  My Daily QA - 2020-09-22 AmazingNutria 4 9,037 09-25-2020, 08:33 AM
Last Post: bcnaz
  My Daily QA - 2020-09-10 AmazingNutria 1 5,061 09-11-2020, 08:30 AM
Last Post: daniel
  Fading screen from 2020 9 8 nightly image HLing 2 6,471 09-10-2020, 04:21 PM
Last Post: HLing
