Questions about Immutable Aspect of UBPorts
Hello, I'm new to UBPorts and had acouple of  questions about it. I have heard that the base system is immutable.
What does this entail for the use of the OS for the user?
What is the difference of this type of OS vs something like Mobian?
Does it support flatpaks? If so is there a way to make the applications fit the screen size?
Lastly, what is the pros and cons of this type of system?
The root filesystem is read-only. While you can mount it read+write and make changes, these will be lost after updates. This feels more like Android, while Mobian and the others are closer to traditional desktop Linux distros.
UBPorts doesn't (currently) support Flatpacks, or Snaps. You can run standard Linux applications through Libertine containers, but currently only command-line programs are supported right now because xwayland is broken. You'll mostly have to stick with apps from the OpenStore.
The main advantage of UBPorts, in my opinion, is the Lomiri desktop, which I prefer to Phosh. Lomiri is currently being packaged for Debian, Postmarket and Manjaro, but for now UBPorts provides the best experience for it.
Ok so it sounds more like an Android system than a vanilla Linux. So when you install an application it goes to a different location than root. How does that work? It has all the files and applications on another partition?
(09-08-2020, 10:50 PM)QazTheWsx Wrote: Ok so it sounds more like an Android system than a vanilla Linux. So when you install an application it goes to a different location than root. How does that work? It has all the files and applications on another partition?
I believe the recomended way is libertine for desktop/cli app containerisation...
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,206 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  online accounts in UBports Uturn 2 7,622 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 17,106 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 5,304 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 4,036 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 29,488 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 14,256 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 8,098 09-30-2020, 12:16 PM
Last Post: defekto
  Dekko on UBPorts PinePhone usable? djvinniev77 13 25,703 09-17-2020, 03:45 PM
Last Post: yurievitch
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 33,895 09-15-2020, 03:42 PM
Last Post: voidmain
