initializing SDRAM Fail on Pine A64+ with 2GB RAM
I've flashed Android 5.1.1 image (March dd image) to a micro SD card, and after spending some time to find a power supply + USB cable combination that would actually boot the board, I get the red LED always on with the following log looping in the serial console:
HELLO! BOOT0 is starting! boot0 commit : 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d boot0 version : 4.0.0 set pll start set pll end rtc[0] value = 0x00000000 rtc[1] value = 0x00000000 rtc[2] value = 0x00000000 rtc[3] value = 0x00000000 rtc[4] value = 0x00000000 rtc[5] value = 0x00000000 DRAM driver version: V1.1 rsb_send_initseq: rsb clk 400Khz -> 3Mhz PMU: AXP81X ddr voltage = 1500 mv DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM clk = 672 MHz DRAM zq value: 003b3bdd DRAM error status 0 DRAM init error! initializing SDRAM Fail.
It looks like some hardware issue with the RAM on the board. Is there a way to set lower DRAM frequency to see if that fixes it?
(04-30-2016, 03:44 AM)cnxsoft Wrote: Is there a way to set lower DRAM frequency to see if that fixes it?
A successful DRAM initialization should read "DRAM zq value: 003b3bbb" instead. And since this happens even before u-boot is loaded I would suspect you're not able to adjust any values here.
Did you try to power the board through the pins on the Euler connector? And use the serial console from the EXP header pins (since then they can't backpower the board which leads to all sorts of strange behaviour and might be related to the problem you're running into)
(04-30-2016, 03:53 AM)tkaiser Wrote: Did you try to power the board through the pins on the Euler connector? And use the serial console from the EXP header pins (since then they can't backpower the board which leads to all sorts of strange behaviour and might be related to the problem you're running into)
The debug board is only connected to the Euler connector via GND, TX and RX, the board is powered via the micro USB port.
There's also jumper for DC5V/BAT (J1 is schematics I think) that was set to BAT by default. So I've tried changing it to DC5V, or removing it, but the result is the same.
I've also made sure to disconnect all devices with only power and serial, but no luck.
Maybe I just have a faulty board.
Ok, so you've a 2GB board. The jumper is to provide USB peripherals either with power from DC-IN or through the PMU.
I asked you to do it differently. Smile
Use jumper wires and connect 5V/GND to pins 4/6 on the Euler connector. And use not the Euler connector for serial console but the EXP connector next to it. If you look into their Wiki you will neither find Euler nor EXP since they call the connectors Eular and Ext instead (for reasons absolutely unknown to me): http://wiki.pine64.org/index.php/Main_Pa...nformation
I have this exact problem with my 1GB board. I emailed their support, and they said they're sending me a new board and will investigate the issue.
(04-30-2016, 04:07 AM)tkaiser Wrote: Ok, so you've a 2GB board. The jumper is to provide USB peripherals either with power from DC-IN or through the PMU.
Thanks, and sorry, I was not thinking clearly at the time. I had also connected my debug board to the EXP, not the larger Euler connector... Anyway, if the board can't boot through micro USB, and would somehow have to power it through the header pins, something is not right here. I use that same power adapter for MiQi board... So I've just contacted them to report the issue, as fire219 did.
  pine store paulhide 1 5,690 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 9,369 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 12,875 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 11,041 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 13,930 09-19-2018, 10:30 AM
Last Post: mjgoode
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 8,282 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 10,599 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 14,784 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Using Pine cluster for Docker Swarm jpnh 1 5,892 11-22-2016, 07:11 AM
Last Post: jpnh
  Pine 64 IR Receiver not working rajatgarg21 1 5,278 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
