Pinephone Community Edition doesn't boot from SD-Card Only Red LED
(09-08-2020, 09:52 AM)robthebold Wrote: September 6 build (#78) boots on 3GB phones
No need to mess around with the nightly/test builds unless you want to. The latest stable release from Sep 5 works on 3GB phones. I'm currently running the F2FS build from eMMC.
Aren't they one and the same in this case, or am I looking in the wrong place? (https://ci.ubports.com/job/rootfs/job/ro...stemimage/)
Are you referring to Mobian "from Sep 5" works ?
On Mobian the Sep 5 release is considered  "stable"  while the "nightly's" are considered cutting edge or testing.
They are listed in the same list on the download page,  but certain ones are considered "stable"
I do not know if ubports has some that are considered as "stable", they may have some also..?
ubports does also do nightly builds like Mobian.
Yes. I'm taking the stable terminology from Mobian and trying to make clear that you don't need a nightly build to boot on a 3GB phone. AFAIK the ability to boot on 3GB phones is what makes the Sep 5 build the latest stable one. That being said, we need people to use the nightly builds. Thanks for your efforts.
To your other point, stable/test builds in UBports are controlled with the options found at System Settings > Updates > Update Settings. I enabled "Release Candidate" to update to OTA-13. At some point, OTA-13 will be promoted to "stable" and be used for the nightly builds. I guess this means that the nightly UBports builds are stable builds, too.
  Pinephone visibly losing power while plugged in Hiraghm 9 8,993 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,685 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,873 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,965 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,659 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,640 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,192 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,835 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,227 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,556 10-21-2025, 12:12 PM
Last Post: Richy_T
