Manjaro ARM Alpha5 for PinePhone!
(09-03-2020, 02:34 AM)Helium75 Wrote: I tested ALPHA-7.
Calls seem to work now - but no sms application installed.
Applying the update via the software store killed the system by cpu overload.
Something with the carrier signal seems to be odd too. Signal strength jumps from 0 to 40% back to 20% and 0 again.
can You receive calls if the phone was in sleep mode and the lockscreen activated?
For me only the lockscreen blinks and no call is receivable. phone app does not start
Spacebar ist the App for SMS
  New PinePhone user issues greenpineuser 8 8,555 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,844 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,139 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,867 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,135 04-02-2024, 11:52 AM
  Manjaro: Settings doesnt open nbh 0 3,368 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,281 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,188 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 7,989 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,730 04-25-2023, 09:49 AM
Last Post: jakfish
