new pinephone received with no battery?
I finally got my new 3gb pinephone.
Plugged it into power, installed postmarketos.
Wifi through phosh doesn't seem to be doing anything.
I popped off the back, and there's no battery.
I'm not supposed to have ordered a battery separately, right?
(09-02-2020, 01:10 PM)senorsmile Wrote: I finally got my new 3gb pinephone.
Nope, there should be a battery supplied. I know they had issues sending "naked batteries" (batteries by themselves), but that shouldn't affect you. It wasn't hidden somewhere in the box was it? If you're desperate, go here: https://wiki.pine64.org/index.php?title=...ne#Battery and source one locally that will fit. And obviously contact the sales support team.
I took pictures of the unboxing, so I had a nice clean area.  I double checked the box, shipping box, inside.  There was a piece of tape where I think it should have been, but just sitting there.  The battery bay is definitely empty.. I can see the contacts where it would connect.
I emailed support.
I believe this is why wifi probably won't work for me ... not enough power to supply the radio.
(09-02-2020, 04:39 PM)senorsmile Wrote: I believe this is why wifi probably won't work for me ... not enough power to supply the radio.
In another thread it was mentioned that wifi doesn't work if there is no battery.
The samsung J7 2015 battery is the battery in the pinephone. You can probably find one locally, and certainly online.
  Pinephone visibly losing power while plugged in Hiraghm 9 8,993 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,686 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,875 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,968 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,659 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,640 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,193 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,835 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,228 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,556 10-21-2025, 12:12 PM
Last Post: Richy_T
