Having trouble compiling Jumpdrive
I am having a great deal of trouble trying to compile Jumpdrive. Specifically, the busybox dependency, but there are other failures. I'm not sure if I need to compile a different version of libc to link to, or if I'm just missing some packages for some cross dependencies. I'll post my build log below, and will answer any further questions if requested. Thank you.
$ make -j$(nproc) pine64-pinephone.img
MAKE  initramfs/bin/busybox
GZ    splash/pine64-pinephone.ppm.gz
GZ    splash/pine64-pinephone-error.ppm.gz
MAKE  kernel-sunxi.gz
MAKE  build/atf/sun50i_a64/bl31.bin
make[1]: Entering directory '/home/PineTrees/src/Jumpdrive/src/busybox'
make[1]: warning: jobserver unavailable: using -j1.  Add '+' to parent make rule.
make[1]: Entering directory '/home/PineTrees/src/Jumpdrive/src/linux'
make[1]: Entering directory '/home/PineTrees/src/Jumpdrive/src/arm-trusted-firmware'
make[2]: Entering directory '/home/PineTrees/src/Jumpdrive/build/linux-sunxi'
  GEN     Makefile
  GEN     Makefile
  HOSTCC  scripts/kconfig/conf.o
  HOSTLD  scripts/kconfig/conf
/usr/bin/ld: /usr/lib/gcc/x86_64-redhat-linux/10/../../../../lib64/crt1.o: in function `_start':
(.text+0x24): undefined reference to `main'
collect2: error: ld returned 1 exit status
make[3]: *** [scripts/Makefile.host:116: scripts/kconfig/conf] Error 1
make[2]: *** [/home/PineTrees/src/Jumpdrive/src/linux/Makefile:568: olddefconfig] Error 2
make[2]: Leaving directory '/home/PineTrees/src/Jumpdrive/build/linux-sunxi'
make[1]: *** [Makefile:179: sub-make] Error 2
make[1]: Leaving directory '/home/PineTrees/src/Jumpdrive/src/linux'
make: *** [Makefile:102: kernel-sunxi.gz] Error 2
make: *** Waiting for unfinished jobs....
scripts/kconfig/conf  --olddefconfig Kconfig
make[3]: scripts/kconfig/conf: Command not found
make[3]: *** [/home/PineTrees/src/Jumpdrive/src/linux/scripts/kconfig/Makefile:75: olddefconfig] Error 127
make: *** [Makefile:102: dtbs/sunxi/sun50i-a64-pinephone.dtb] Error 2
  GEN     /home/PineTrees/src/Jumpdrive/build/busybox/Makefile
  CC      bl31/bl31_context_mgmt.c
  CC      bl31/bl31_main.c
  CC      bl31/interrupt_mgmt.c
  Using /home/PineTrees/src/Jumpdrive/src/busybox as source for busybox
  CC      common/runtime_svc.c
  CC      drivers/allwinner/axp/axp803.c
  CC      drivers/allwinner/axp/common.c
  CC      drivers/allwinner/sunxi_msgbox.c
  CC      drivers/allwinner/sunxi_rsb.c
  CC      drivers/arm/css/scpi/css_scpi.c
  CC      drivers/arm/gic/common/gic_common.c
  CC      drivers/arm/gic/v2/gicv2_helpers.c
  CC      drivers/arm/gic/v2/gicv2_main.c
  CC      drivers/delay_timer/delay_timer.c
  CC      drivers/delay_timer/generic_delay_timer.c
  CC      lib/cpus/errata_report.c
  CC      lib/el3_runtime/aarch64/context_mgmt.c
  CC      lib/el3_runtime/cpu_data_array.c
  CC      lib/locks/bakery/bakery_lock_coherent.c
  CC      lib/psci/psci_common.c
scripts/kconfig/conf -s Config.in
# using defaults found in .config
  CC      lib/psci/psci_main.c
  CC      lib/psci/psci_mem_protect.c
  CC      lib/psci/psci_off.c
  CC      lib/psci/psci_on.c
  CC      lib/psci/psci_setup.c
  CC      lib/psci/psci_suspend.c
  CC      lib/psci/psci_system_off.c
  CC      plat/allwinner/common/sunxi_bl31_setup.c
  CC      plat/allwinner/common/sunxi_cpu_ops.c
  CC      plat/allwinner/common/sunxi_pm.c
  CC      plat/allwinner/common/sunxi_security.c
  CC      plat/allwinner/common/sunxi_topology.c
  CC      plat/allwinner/sun50i_a64/sunxi_power.c
  CC      plat/common/plat_gicv2.c
  CC      plat/common/plat_psci_common.c
  CC      services/arm_arch_svc/arm_arch_svc_setup.c
  CC      services/std_svc/std_svc_setup.c
  CC      common/bl_common.c
  CC      common/tf_log.c
  CC      drivers/console/multi_console.c
  CC      plat/common/plat_bl_common.c
  CC      plat/common/plat_log_common.c
  CC      plat/common/aarch64/plat_common.c
  CC      lib/compiler-rt/builtins/popcountdi2.c
  CC      lib/compiler-rt/builtins/popcountsi2.c
  CC      lib/xlat_tables_v2/aarch64/xlat_tables_arch.c
  CC      lib/xlat_tables_v2/xlat_tables_context.c
  CC      lib/xlat_tables_v2/xlat_tables_core.c
  CC      lib/xlat_tables_v2/xlat_tables_utils.c
  SPLIT   include/autoconf.h -> include/config/*
  CC      plat/allwinner/common/sunxi_common.c
  GEN     include/bbconfigopts.h
  GEN     include/common_bufsiz.h
  AS      bl31/aarch64/bl31_entrypoint.S
  AS      bl31/aarch64/crash_reporting.S
  AS      bl31/aarch64/ea_delegate.S
  AS      bl31/aarch64/runtime_exceptions.S
  GEN     include/embedded_scripts.h
  AS      lib/cpus/aarch64/cortex_a53.S
  AS      lib/cpus/aarch64/cpu_helpers.S
  AS      lib/cpus/aarch64/dsu_helpers.S
  HOSTCC  applets/usage
  HOSTCC  applets/applet_tables
  AS      lib/cpus/aarch64/wa_cve_2017_5715_bpiall.S
  AS      lib/cpus/aarch64/wa_cve_2017_5715_mmu.S
  AS      lib/el3_runtime/aarch64/context.S
  AS      lib/el3_runtime/aarch64/cpu_data.S
  AS      lib/locks/exclusive/aarch64/spinlock.S
  GEN     include/usage_compressed.h
  AS      lib/psci/aarch64/psci_helpers.S
  AS      plat/common/aarch64/platform_mp_stack.S
  GEN     include/applet_tables.h include/NUM_APPLETS.h
  HOSTCC  applets/usage_pod
  AS      common/aarch64/debug.S
  AS      lib/aarch64/cache_helpers.S
  AS      lib/aarch64/misc_helpers.S
  AS      plat/common/aarch64/platform_helpers.S
  CC      applets/applets.o
In file included from /home/PineTrees/src/Jumpdrive/src/busybox/include/libbb.h:13,
                 from /home/PineTrees/src/Jumpdrive/src/busybox/include/busybox.h:8,
                 from /home/PineTrees/src/Jumpdrive/src/busybox/applets/applets.c:9:
/home/PineTrees/src/Jumpdrive/src/busybox/include/platform.h:164:11: fatal error: byteswap.h: No such file or directory
  164 | # include <byteswap.h>
compilation terminated.
make[3]: *** [/home/PineTrees/src/Jumpdrive/src/busybox/scripts/Makefile.build:198: applets/applets.o] Error 1
make[3]: *** Waiting for unfinished jobs....
  AS      drivers/ti/uart/aarch64/16550_console.S
make[2]: *** [/home/PineTrees/src/Jumpdrive/src/busybox/Makefile:372: applets_dir] Error 2
make[1]: *** [Makefile:112: _all] Error 2
make[1]: Leaving directory '/home/PineTrees/src/Jumpdrive/src/busybox'
make: *** [Makefile:76: initramfs/bin/busybox] Error 2
  AS      lib/xlat_tables_v2/aarch64/enable_mmu.S
  AS      plat/allwinner/common/plat_helpers.S
  PP      bl31/bl31.ld.S
  CC      lib/libfdt/fdt.c
  CC      lib/libfdt/fdt_addresses.c
  CC      lib/libfdt/fdt_empty_tree.c
  CC      lib/libfdt/fdt_ro.c
  CC      lib/libfdt/fdt_rw.c
  CC      lib/libfdt/fdt_strerror.c
  CC      lib/libfdt/fdt_sw.c
  CC      lib/libfdt/fdt_wip.c
  AR      build/sun50i_a64/release/lib/libfdt.a
  CC      lib/libc/abort.c
  CC      lib/libc/assert.c
  CC      lib/libc/exit.c
  CC      lib/libc/memchr.c
  CC      lib/libc/memcmp.c
  CC      lib/libc/memcpy.c
  CC      lib/libc/memmove.c
  CC      lib/libc/memrchr.c
  CC      lib/libc/memset.c
  CC      lib/libc/printf.c
  CC      lib/libc/putchar.c
  CC      lib/libc/puts.c
  CC      lib/libc/snprintf.c
  CC      lib/libc/strchr.c
  CC      lib/libc/strcmp.c
  CC      lib/libc/strlcpy.c
  CC      lib/libc/strlen.c
  CC      lib/libc/strncmp.c
  CC      lib/libc/strnlen.c
  CC      lib/libc/strrchr.c
  AS      lib/libc/aarch64/setjmp.S
  AR      build/sun50i_a64/release/lib/libc.a
  LD      build/sun50i_a64/release/bl31/bl31.elf
  BIN     build/sun50i_a64/release/bl31.bin
Built build/sun50i_a64/release/bl31.bin successfully
  OD      build/sun50i_a64/release/bl31/bl31.dump
make[1]: Leaving directory '/home/PineTrees/src/Jumpdrive/src/arm-trusted-firmware'
rm splash/pine64-pinephone-error.ppm.gz splash/pine64-pinephone.ppm.gz
  8/24 status of JumpDrive shengchieh 6 5,085 11-14-2026, 06:38 AM
Last Post: deltaexploitss
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,941 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Trouble building (& using) pinephone-keyboard tools 64_Tesseract 6 9,356 08-28-2022, 09:42 PM
Last Post: 64_Tesseract
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 7,256 05-02-2022, 06:57 AM
Last Post: Peter Gamma
  Cross compiling wakyct 5 7,152 12-17-2021, 08:16 PM
Last Post: wakyct
