Pinebook doesn't charge anymore
Dear folks,
my Pinebook won't charge any more; there doesn't seem to be anything wrong with the charger brick though. I followed the advice on this forum for battery problems but that only made things worse but I did discover that indeed its the charger circuit.
For the battery reset, i had to unplug the battery cable while the mains was on but this instantly gave a power loss to the machine so no power was arriving from the power cable and it was just running on fumes so to say of the little that was still in the battery although it showed 0% power. The situation is now that it runs on the fumes but at the same time reports there is no battery :-S
Is this charger part replaceable and what PCB is it? The USB connector on the PCB with the power plug and the SDcard is in working order so i doubt its the cabling between the PCBs. Can I order a new side PCB or do I need to replace the main PCB?
With regards,
Reinoud Zandijk
  Running Pinebook (non-Pro) without battery? guidol 0 3,183 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 12,368 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 7,272 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,951 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 4,365 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 4,296 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,987 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 8,919 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 6,881 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 7,996 01-13-2021, 11:03 AM
Last Post: barray
