Zotero on PBP?
Does anybody in this forum use Zotero too?
I have been using Zotero on my PBP with 'zotero-arm-bin' package from AUR, but the recent kernel update broke the software.
I am not exactly familiar enough with Linux to change the contents of the package. I would appreciate any help about this issue.
When I try to start the program, I get the following error message.
XPCOMGlueLoad error for file /usr/lib/zotero/libxul.so:
libstartup-notification-1.so.0: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
it is a binary package so probably does not list all dependencies. search for libstartup-notification and install manually. the pkgbuild also extracts the amd64 package and a new one is here: https://www.zotero.org/support/dev_builds
(08-19-2020, 11:28 PM)xmixahlx Wrote: it is a binary package so probably does not list all dependencies. search for libstartup-notification and install manually. the pkgbuild also extracts the amd64 package and a new one is here: https://www.zotero.org/support/dev_builds
https://altlinux.pkgs.org/sisyphus/class...4.rpm.html
Thank you for the reply. Is this the correct dependency for libstartup-notification? I could only find red hat package.
