Arch Linux Arm - external RTC problem
I have connected an external RTC module (ds3231) to a Rock 64/4g.
I've loaded i2c-dev modules and rtc-ds1307 modules but my rtc mod is not detected by i2c (i2cdetect shows nothing connected at address 68)
Hardware is ok (if I boot with ayurfan distro I can see the external RTC module).
Could it be a kernel configuration problem? Has anyone had similar experience?
My Linux distro is Arch Linux Arm.
Regards
Max
if anyone would be interested I managed to make it all work.
- i've modified, recompiled and overwrite to original one (in /boot/dtb) rk3328-rock64.dts, adding this fragment of code
  &i2c0 {       status = "okay";       ds1307: ds1307@68 {         compatible = "maxim,ds1307";         reg = <0x68>;         status = "okay";       };       ds3231: ds3231@68 {         compatible = "maxim,ds3231";         reg = <0x68>;         status = "okay";       }; };
to enable i2c0 bus and to let automatically discovered the rtc device by the kernel at boot time.
- blacklisted rock64 rtc module (rtc_rk808)
- added rtc_ds1307 module to automatic module loading system
After reboot rtc device will be created and the rtc module enabled
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,905 09-27-2026, 11:55 AM
  problem with debian emmc boot G4zCDzWb 10 31,161 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 5,168 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 Debian 11 (Bullseye) install problem jbize 15 25,343 10-12-2023, 05:14 PM
Last Post: tpaul
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 5,141 06-02-2023, 07:52 AM
Last Post: diederik
  Looking for guidance on setting up with external RTC Ditchmagnet 0 2,529 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
  Linux 5.15 Kernel - openSuse mark1250 0 3,087 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 30,996 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 3,136 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 148,513 05-14-2021, 10:41 AM
Last Post: Wizzard
