Funny Conky like script to monitor your PBP state
I found it this script useful. So I'm sharing it.
It monitors CPU/GPU frequencies, temperatures and gives basic info from top.
#!/bin/bash a53=$(cat /sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq | awk '{print $1 / 1000000}') a72=$(cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq | awk '{print $1 / 1000000}') cpu=$(cat /sys/class/thermal/thermal_zone0/temp) gpuf=$(cat /sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/cur_freq | awk '{print $1 / 1000000}') gpu=$(cat /sys/class/thermal/thermal_zone1/temp) echo CPU temperature '>' ${cpu::2}C echo GPU temperature '>' ${gpu::2}C echo A53 Little frequency '>' ${a53}Ghz echo A72 Big frequency '>' ${a72}Ghz echo GPU frequency '>' ${gpuf}Mhz echo "" top 1 -bn1 | head -10
Copy code, save as eg. script.sh. Then:
chmod +x script.sh
If you want to refresh information every 0.5 seconds:
watch -n 0.5 script.sh
Every 2 seconds:
watch -n 2 script.sh
thanks. i'll check this out with stress testing.
i've found the simple CPU temp monitor in sway is sufficient for my needs, but do set the governor to conservative and tweak power settings for conservation.
  External USB C Monitor not working altacus 29 67,853 08-08-2021, 10:19 AM
Last Post: Dendrocalamus64
  Netflix, state of the art? gleachkr 82 173,259 03-24-2021, 03:42 PM
Last Post: wrzomar
  kodi-git build script for mainline hwaccel media decoding xmixahlx 21 49,734 11-01-2020, 05:17 PM
Last Post: xmixahlx
Question Manjaro XFCE: video outputs (Multi-monitor) EreTIk 2 7,054 03-23-2020, 11:20 AM
Last Post: EreTIk
Shocked Pinebook Pro Build Script Issues TDC_PBP 3 9,381 03-01-2020, 04:24 PM
Last Post: jwhall
  Connected to 4k (3840x2160) monitor but I can only select upto 1920x1080 resolution NigelT 4 12,628 01-27-2020, 01:19 PM
Last Post: xmixahlx
  State of hibernate or hybrid-sleep? Arwen 5 12,427 11-21-2019, 07:51 AM
Bug MATE System Monitor shows seven CPU cores in Debian User 11436 2 7,900 11-07-2019, 11:32 AM
Last Post: hmuller
