Why no DVI-HDMI video?
Hey,
So I recently bought a new monitor for my Pine64 that has a DVI in. HDMI and DVI are both digital, so I bought a converter cable to connect my pine to the monitor. It doesn't work unfortunately (black screen.) I just googled it today and found on the wiki that...
"Do not use a DVI-HDMI adapter. If you want video output, use a HDMI cable direct to a HDMI monitor or TV. This may change as development continues."
Why is this? Would it work if I installed a different flavor of linux on my card instead of using the image given?
No other favour or linux would remedy this. The display driver changes from RGB to YPbPr when using an adapter which is causing the problem you are experiencing. Some adapters work, others don't - I have no explanation as to why this is: http://forum.pine64.org/showthread.php?tid=827
  Disable HDMI Pine64 Andruxa89 1 7,577 01-31-2019, 11:18 AM
Last Post: martinayotte
  Background Video Conversion connorja 2 6,756 07-10-2017, 12:14 PM
Last Post: connorja
  Unsupported video mode warning in dmesg utdrmac 1 6,348 02-01-2017, 01:17 PM
Last Post: MarkHaysHarris777
  How to set video output to 4K / UltraHD? Pander 11 23,358 10-20-2016, 08:00 AM
Last Post: Pander
  cannot play any video aneryan 5 11,438 10-04-2016, 04:59 AM
Last Post: pfeerick
  HDMI Overscan problem luke2389 8 17,965 09-02-2016, 10:22 PM
Last Post: Terra854
Question Handbrake settings for video conversion on Ubuntu Xenial pelgrim 4 11,541 08-11-2016, 07:35 AM
Last Post: waldo
  Video Drivers Gnx 0 3,690 07-04-2016, 04:48 PM
Last Post: Gnx
  Ubuntu: video lag romangaag 4 11,140 05-03-2016, 10:53 PM
Last Post: romangaag
