Touchscreen broken on arrival [*now with video*]
(06-20-2020, 06:09 AM)ozzeruk Wrote: To update and complete this post.
On Thursday I received a new LCD touchscreen sent free of charge by Pine64.
I installed it myself and reconstructed the phone. The issue has now entirely disappeared!
I'm very pleased - if anyone else has a similar problem, then it is most likely the touchscreen.
Very glad your issue had been resolved.  I am curious as to how easy/difficult it was to replace the glass.  Mine arrived perfectly functional, with a couple of dead pixels on the very top left corner which doesn't affect anything. Alas, a month after using it my clumsiness had it slid down (face down) the dashboard in a car.  The top portion had small cracks and some pieces have gone missing.  I had since put scotch tape over it to prevent more pieces breaking off.  If this repair isn't necessary other than cosmetic, I would probably leave it as is. In the event that things start to get funny, I would consider purchasing a replacement glass.  That is, if it wouldn't be too difficult for me to replace myself.  Can you share your experience and if you'd found instructions where the source might be?
Thank you!
  Pinephone - broken power button rorus 14 26,285 05-17-2026, 03:52 PM
Last Post: EuvzO8
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,327 06-21-2025, 05:19 PM
Last Post: mikeb
Exclamation Impossible to login, bottom right corner of the touchscreen not responding anonymous 2 4,085 02-24-2025, 06:57 AM
Last Post: anonymous
Photo Can no longer take pictures, /dev/video* not recognized as video devices 64_Tesseract 0 2,004 01-26-2023, 10:19 AM
Last Post: 64_Tesseract
  720p video in Firefox notramo 4 6,126 11-28-2022, 06:09 AM
Last Post: dante404
  Keyboard support broken in Mobian? MacarioMorenoUK 2 4,972 06-08-2022, 02:34 AM
Last Post: MacarioMorenoUK
Sad Have I got a broken camera module? AKD251 2 5,114 11-07-2021, 11:12 AM
Last Post: beta-user
  [Help] SIM slot contact broken WinstonSmith 3 8,324 07-14-2021, 06:13 AM
Last Post: mouffa
Video Questions about filming video with the Pinephone MirceaKitsune 10 21,104 06-02-2021, 01:47 PM
Last Post: vortex
  PinePhone won't boot, U-Boot seems to be broken Marcade 8 15,086 04-20-2021, 05:28 PM
Last Post: dsimic
