Arch Killing long running node/npm processes before finishing
Question
hello all,
when i run certian longer processes in node.js/npm, like an update ($ npm update -g) or to search for an npm package ($ npm search elm), it starts the process on my Pine64 A64+ w/ 2 GB board, but then half- or even three-quarters of the way through, it just kills the process before it completes; particularly, i noticed, when it's waiting for info to come back across the 'net through the ethernet port, with —
Killed
then it just gives me the command prompt again, process never completes. this happens no matter how many times i re-try it.
is there anyway to change a setting, somewhere, that will extend the amount of time before these processes are killed? any help would be much appreciated, please. thank you and advance.
best,
—  faddah
     portland, oregon, u.s.a.
Can you please provide the output of 'uname -a' and 'cat /proc/meminfo'
(04-28-2016, 10:59 AM)@tkaiser Wrote: Can you please provide the output of 'uname -a' and 'cat /proc/meminfo'
@tkaiser —
sure! thank you for the help.
$ uname -a Linux alarm 3.10.65-2-pine64-longsleep #39 SMP PREEMPT Fri Mar 4 21:55:14 CET 2016 aarch64 GNU/Linux $ cat /proc/meminfo MemTotal:                    1002164 KB MemFree:                      568180 KB Buffers:                       86380 KB Cached:                        95496 KB SwapCached:                        0 KB Active:                       258452 KB Inactive:                      89028 KB Active(anon):                 155952 KB Inactive(anon):                 2104 KB Active(file):                  92500 KB Inactive(file):                86924 KB Unevictable:                       0 KB Mlocked:                           0 KB SwapTotal:                         0 KB SwapFree:                          0 KB Dirty:                             0 KB Writeback:                         0 KB AnonPages:                    155648 KB Mapped:                         7692 KB Shmem:                          2428 KB Slab:                          58608 KB SReclaimable:                  43192 KB SUnreclaim:                    15416 KB KernelStack:                    2576 KB PageTables:                     2692 KB NFS_Unstable:                      0 KB Bounce:                            0 KB WritebackTmp:                      0 KB CommitLimit:                  501080 KB Commit_AS:                    746612 KB Vmalloctotal:              251658176 KB Vmallocused:                   23944 KB Vmallocchunk:              251625116 KB HugePages_Total:                   0 KB HugePages_Free:                    0 KB HugePages_Rsvd:                    0 KB HugePages_Surp:                    0 KB Hugepagesize:                   2048 KB
there you go. please let me know and thank you for the help.
best,
—  faddah
Thx for the answer. The OS image you're using is obviously only able to recognize 1 GB RAM (know issue, fixed by longsleep ages ago) and also the kernel is rather outdated. By simply executing the three lines below you get 1 GB more useable DRAM, a fixed MAC address without any hassles and a bunch of other fixes for free.
Unfortunately the Pine64 folks do a really really bad job providing necessary informations (maybe for a reason? Marketing matters) and all you need to do is to update both u-boot and kernel.
Please read through these instructions:
- http://forum.pine64.org/showthread.php?tid=737
- http://forum.pine64.org/showthread.php?tid=293
TL;DR: To update any of the available OS images all that's needed is just the following executed as root followed by a reboot:
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_uboot.sh) bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh) bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh)
It's a shame that such essential information isn't provided at the download location where every new user searches for software.
Regarding your real issue I would suspect reading through 'man nohup' should be able to solve the issue? Smile
(04-28-2016, 10:14 AM)faddah Wrote:
hello all,
Killed
best,
—  faddah
Linux doesn't normally kill processes that run long. Try "dmesg | tail" after the process is killed to see if something like oom is killing it.
  what/where is the package manager on Arch Linux? spruce1 9 20,494 04-03-2019, 05:58 AM
Last Post: jose.ramirez
  Arch Linux mainline XFCE pineadmin 12 46,569 02-21-2019, 05:52 AM
Last Post: starcrescent
  Arch Linux image (BSP Kernel) longsleep 28 102,300 05-06-2016, 06:33 PM
  Archlinux up and Running scnd 4 11,614 04-30-2016, 06:42 PM
Last Post: Leoncito81
