Pinephone tethering?
Hi folks,
It is quite common for Android phones to share mobile broadband connection via wifi/bluetooth/usb to you can browse internet in other devices that doesn't have mobile broadband capabilities (aka tethering).
Has anyone tried to make tethering work with the pinephone? I guess the most difficult part would be to set the wireless interface in 'master' mode to be able to run hostapd or something similar... (IDK if the chipset supports master mode)
Thoughts?
Thanks!
(07-23-2020, 03:13 AM)e-minguez Wrote: Hi folks,
Thoughts?
Thanks!
Sure. Wifi hotspot works on Mobian. Bluetooth has to be enabled first to get the menu entry though. It can be safely disabled afterwards.
Thoughts?
Thanks!
Aaaaaaaaaaaaaand it works!!! Thanks for the quick how-to Smile
  Pinephone visibly losing power while plugged in Hiraghm 9 8,979 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,669 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,829 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,905 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,645 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,635 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,189 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,830 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,225 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,539 10-21-2025, 12:12 PM
Last Post: Richy_T
