Alarm clock doesn’t work
I don’t know where else to post this, but the alarm clock function in the clock app does not work. I updated as recently as yesterday evening. Just putting this out there again, if there is a better place for trivial bug reports please direct me there. Thanks again for all the amazing work and rapid progress to this point.
(07-20-2020, 12:45 PM)Captain1ndustry Wrote: I don’t know where else to post this, but the alarm clock function in the clock app does not work. I updated as recently as yesterday evening. Just putting this out there again, if there is a better place for trivial bug reports please direct me there. Thanks again for all the amazing work and rapid progress to this point.
Yes I noticed the same, not sure where to file a bug report myself.
For the interm as a work around I have been using a cronjob and music123
apt install music123
crontab -e
and add something like
0 7 * * * /usr/local/bin/alarm.sh
and in alarm.sh have something like
#!/bin/bash
for i in `seq 1 10`; do
    music123 /usr/share/sounds/freedesktop/stereo/alarm-clock-elapsed.oga
done
which plays the alarm clock sound 10 times in a row
The unfortunate thing is that doing so will be quite difficult to turn off and it is kindof quiet. You could modify the script to fix this a number of ways I am certain. My initial thought would be check for a file, but making a file takes more time than the thing plays for. Maybe an adaption to check if the flashlight app is running... then you could start the flashlight app to turn it off.
(07-20-2020, 12:45 PM)Captain1ndustry Wrote: but the alarm clock function in the clock app does not work.
Did you activate it after you programmed it?
Cause I tested it and it's working at my place.
Also just tested and it worked fine. (A couple of weeks ago I tested and it did not work but seems that is history.)
Make sure your volume is loud enough.
The alarm doesn't wake the phone for me, if I set the alarm for more than the sleep time, it only goes off when I wake the phone manually.
(07-24-2020, 09:33 PM)scott_VYuCAbn3k1NFK Wrote: The alarm doesn't wake the phone for me, if I set the alarm for more than the sleep time, it only goes off when I wake the phone manually.
I have been thinking about this. I think the "Clock app" will need to be modified to set a timer interrupt or similar so as to wake the phone in time to sound the alarm.
Experimenting with linux RTC ... will see if this works.
Preliminary testing using "rtcwake" does work a treat.
To test, set the alarm for some time, say a couple hours later, to be sure the pinephone is nicely asleep when the alarm is supposed to sound.
The set "rtcwake";
sudo rtcwake -m no -l -t "$(date -d 'today 16:00:00' '+%s')"
where  -m no means dont suspend/sleep now, -l means local time, -t the time and date string when to wake up.
Note: kernel time needs to be same as local time, in the above example, or you will need to work out the difference.
Check this with;
sudo hwclock -r
Next steps will be to see if it will be possible to change the clock code or write a new clock program.  Will be interesting how to handle multiple alarms.
I wrote an alarm clock app which wakes the device through systemd timers setting the RTC device clock: https://gitlab.gnome.org/kailueke/wake-mobile
Mobian packages are linked in the README
Great work on this, working timer and alarms in the Clocks app would be very useful. Thanks!
  The program doesn`t detect the camera blag0rag 6 6,446 09-17-2024, 03:45 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 7,348 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 6,732 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 4,598 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 15,851 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  German Emergency Alarm System Test arno_nuehm 4 6,164 12-11-2022, 01:44 PM
Last Post: traut
Exclamation The webcam doesn't work in Firefox anonymous 0 2,269 11-06-2022, 01:45 PM
Last Post: anonymous
  Megapixels doesn't work Glenn 4 7,612 08-28-2022, 03:19 PM
Last Post: vortex
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 3,238 08-06-2022, 01:10 AM
Last Post: elode
  Can't Get Nheko To Work [never mind, it's a bug] el.pollo.diablo 0 2,194 08-02-2022, 02:11 AM
Last Post: el.pollo.diablo
