Mainline kernel not working (no screen)
Hi all,
I successfully started a Debian 10 ARM64 rootfs + initrd, preinstalled using QEMU with LXDE and autologin. For a touch screen this is not easy to use, but I expect using keyboard and mouse soon Smile
Using the 5.6.0-pine64 kernel which was provided with Ubuntu at delivery few weeks ago, having included the 5.6.0-pine64 modules into the debian's initrd, and having the "fstab" file corrected into rootfs, it boots fine. I customised the U-Boot boot script too.
However, I tried to do the same with a 5.8.0-rc5 kernel, using the config-5.6.0-pine64 as .config file for building the 5.8.0-rc5 kernel.
But I have no screen. I tried disabling "Enable loadable module support" so that every driver is embedded/preloaded into the kernel, but nothing more.
When comparing resulting .config, the following lines are missing after having 5.8.0-rc5 kernel built :
CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_MEMCG_SWAP_ENABLED=y CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT_VHE=y CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT_NVHE=y CONFIG_ARM64_LSE_ATOMICS=y CONFIG_ARM64_PTR_AUTH=y CONFIG_PLUGIN_HOSTCC="" CONFIG_HAVE_MEMBLOCK_NODE_MAP=y CONFIG_TRANSPARENT_HUGE_PAGECACHE=y CONFIG_VEXPRESS_SYSCFG=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_VIDEO_SUN4I_CSI=m CONFIG_VIDEO_SUN6I_CSI=m CONFIG_V4L_MEM2MEM_DRIVERS=y CONFIG_DRM_PANEL_PINEPHONE_JD9365DA=y CONFIG_DRM_PANEL_XINGBANGDA_XBD599=y CONFIG_DRM_I2C_ADV7533=y CONFIG_SND_SOC_EC25=m CONFIG_USB_CHIPIDEA_OF=m CONFIG_RTL8723CS_NEW=m CONFIG_COMMON_CLK_VERSATILE=y CONFIG_CLK_SP810=y CONFIG_CLK_VEXPRESS_OSC=y CONFIG_CLKSRC_MMIO=y CONFIG_CLKSRC_VERSATILE=y CONFIG_RPMSG_QCOM_GLINK_NATIVE=y CONFIG_OPTIMIZE_INLINING=y CONFIG_UBSAN_ALIGNMENT=y
I guess the fact of having CONFIG_DRM_PANEL_PINEPHONE_JD9365DA missing may be one of the reasons why I have nothing on the screen...
Are you sure that mainline kernel can really be used on the pinephone?
If so, is there some diffconfig or pinephone64-defconfig somewhere?
Thank you in advance!
There are still patches which haven't made it to mainline yet, I don't expect the phone to be fully functional before 5.9 at least.
The main issue regarding the display is that CONFIG_DRM_PANEL_XINGBANGDA_XBD599 (that's the one for v1.1+, the other was for the devkit) has been renamed to CONFIG_DRM_PANEL_SITRONIX_ST7703 since 5.7.
I suggest you start with a 5.7 defconfig, either from Mobian's repo or the one provided by Pine64.
Anyway, based on your defconfig diff, I assume camera, wifi and modem audio won't work at all with mainline (due to the lack of SUN6I_CSI, RTL8723CS_NEW and SND_SOC_EC25).
But you should be able to boot and use most of the features (including mobile data) without these Wink
FWIW, I'm a huge fan of debos when it comes to building custom debian images, I suggest you have a look here, with a few tweaks you'll be able to make a pure Debian image in no time Wink
Thank you for this information, this is exactly what I needed, and even more Smile
Just for information by the way, about using official Debian with a compatible kernel
I used Mobian Kernel with arch/arm64/boot/dts/allwinner/sun50i-a64-pinephone-1.2.dtb (as my phone is UBport Edition / Community Edition, which is supposed to be 1.2, if I'm right). By the way, KVM is working on it (opened 2 KVM running in parallel! Will probably install Windows 10 arm64 soon or late just for fun Wink ).
Even when using a compatible kernels, appart from WiFi, it seems to need some tweaks to have everything working.
WiFi (2.4 GHz) is performing well, about 50 Mbps on 20MHz bandwidth and about 100 Mbps on 40 MHz bandwidth.
Used network-manager-gnome (which is working fine on both IPv4 and IPv6 settings), but I guess others network managers can be used.
For information, I got bluetooth working by adding to Debian rootfs and initrd the following files :
/lib/firmware/rtl_bt/rtl8723cs_xx_fw.bin
/lib/firmware/rtl_bt/rtl8723cs_xx_config-pinebook.bin
Because I saw in dmesg some errors about those files missing. Took them from Ubuntu Touch, as they weren't included into "apt install firmware-realtek".
Using "blueman" as bluetooth manager for connecting mouse and keyboard, now works fine into Debian 10 / LXDE
Still with Mobian kernel, looks like the USB C driver (anx7688) is included, making "port0" available into /sys/class/typec/
But according to https://xnux.eu/devices/feature/anx7688.html, an EEPROM should be flashed with a working firmware before being able to use it on the pinephone.
Did so by downloading https://xff.cz/git/linux-firmware/plain/anx7688-fw.bin to /lib/firmware and running echo 1 > /sys/class/typec/port0/device/flash_eeprom
As I didn't reworked the defective hardware conception grounding "CC" signal (see this tutorial https://xnux.eu/devices/pp-usbc-fix.jpg), in order to connect an USB-C hub, I would need to manually ask software to become "host" but I had no success in doing so :
root@pinecrobe:/sys/class/typec/port0# echo device > /sys/class/typec/port0/data_role bash: echo: write error: Unknown error 524 root@pinecrobe:/sys/class/typec/port0# echo host > /sys/class/typec/port0/data_role bash: echo: write error: Unknown error 524
According to linux kernel source file "#include <uapi/linux/errno.h>", Unknown error 524 is #define ENOTSUPP  524 /* Operation is not supported */
But may be another command should be used, I don't know.
Modem :
I still have a problem with it.
On Ubuntu Touch, after 20 seconds, something makes a new USB device visible, which is the modem :
[  20.366175] usb 3-1: new high-speed USB device number 2 using ehci-platform [  20.577030] usbcore: registered new interface driver option [  20.577084] usbserial: USB Serial support registered for GSM modem (1-port) [  20.577431] option 3-1:1.0: GSM modem (1-port) converter detected [  20.581267] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0 [  20.581643] option 3-1:1.1: GSM modem (1-port) converter detected [  20.590260] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1 [  20.590797] option 3-1:1.2: GSM modem (1-port) converter detected [  20.594813] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2 [  20.595147] option 3-1:1.3: GSM modem (1-port) converter detected [  20.601957] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
Then "modem-manager" (which I run using ssh -X root@Phone_IP) is able to play with it.
But from Debian, I still don't know what is used to trigger this apparition (is this a pinephone hardware specific i2c message sent by ubuntu touch to wake something, or something else ?)
I guess the answer may be available somewhere into https://gitlab.com/mobian1/mobian-recipes (thanks a-wai for the link)
EDIT : looks like into Ubuntu Touch, the "oFono" service used to interract with the modem and modem-manager, (which is available into Debian), has a customized boot script for the pinephone, containing really clear things : the modem needs to be powered on from GPIO signals.
description "oFono Mobile telephony stack" start on started dbus stop on stopping dbus pre-start script echo "Enabling EG25 WWAN module" # GPIO35 is PWRKEY # GPIO68 is RESET_N # GPIO232 is W_DISABLE# for i in 35 68 232 do [ -e /sys/class/gpio/gpio$i ] && continue echo $i > /sys/class/gpio/export || return 1 echo out > /sys/class/gpio/gpio$i/direction || return 1 done echo 0 > /sys/class/gpio/gpio68/value || return 1 echo 0 > /sys/class/gpio/gpio232/value || return 1 ( echo 1 > /sys/class/gpio/gpio35/value && sleep 2 && echo 0 > /sys/class/gpio/gpio35/value ) || return 1 end script post-start script     /usr/bin/enable-modem end script post-stop script echo "Disabling EG25 WWAN module" echo 1 > /sys/class/gpio/gpio68/value echo 1 > /sys/class/gpio/gpio232/value echo 1 > /sys/class/gpio/gpio35/value && sleep 2 && echo 0 > /sys/class/gpio/gpio35/value end script expect fork respawn exec ofonod
But I read somewhere that this modem needs some attention at poweroff to avoid corruption of the internal memory. Will try to find back all needed information before trying anything.
According to : https://wiki.pine64.org/PinePhone#Modem_...er_Support
Quote:There is a document about using the modem from January 18th 2020 by user megi here*. The script at the end to disable the modem before power off is pretty essential to avoid corrupting your modem's flash memory.
here* : https://megous.com/dl/tmp/modem.txt
And here : https://xnux.eu/devices/feature/modem-pp.html
Quote:Via sysfs (since 5.6):
# request powerup
echo 1 > /sys/devices/platform/modem/powered
# request powerdown
echo 0 > /sys/devices/platform/modem/powered
# read power status (changes only after power state transition is complete)
cat /sys/devices/platform/modem/powered
# It's also possible to change the powerdown safety delay (in ms):
cat /sys/devices/platform/modem/powerdown_safety_delay
echo 10000 > /sys/devices/platform/modem/powerdown_safety_delay
And audio is still not working (visible outputs and inputs aren't working, even when disabling mute and moving volume up) so a pinephone specific tweak is probably needed here too.
I strongly suggest you have a look at the various Mobian repos, especially the pinephone-related ones:
- modem scripts for power on/off and modem setup are in, well, pinephone-modem-scripts
- other PP-specific tweaks are in package pinephone-tweaks
- Wifi/BT firmware files are in firmware-rtl8723cs
Still not sure about the anx7688 firmware (we would probably need analogix's permission for that)
EDIT: Oh, and packages/alsa-ucm-conf might help with audio too Wink
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,809 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,532 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,344 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,588 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,764 07-18-2025, 07:56 PM
  New camera app gnome-snapshot working on trixie? vusra 4 5,350 04-11-2025, 02:53 AM
Last Post: vusra
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,745 01-15-2025, 08:08 PM
  how to disable ipv6 at kernel level with towboot? vusra 3 5,263 10-04-2024, 04:23 AM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 5,832 08-06-2024, 02:20 PM
Last Post: baptx
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,966 08-05-2024, 06:12 AM
Last Post: baptx
Users browsing this thread:
