Moving windows in Phosh
Is there a way to enable window dragging in phosh? I want to use qmmp but it opens at the bottom of the screen so I can't use the menus
(07-03-2020, 03:13 AM)NO_ob Wrote: Is there a way to enable window dragging in phosh? I want to use qmmp but it opens at the bottom of the screen so I can't use the menus
I have not figured out how to do that in phosh. If you install Fedora you get a choice on login of phosh or GNOME and dragging windows works on GNOME.
If you try this, on my phone GNOME is listed multiple times in the list of sessions, and it's the second one that works for me
  Fedora + Phosh for PinePhone njha 77 236,193 01-14-2026, 12:22 AM
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 3,492 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 28,422 03-31-2023, 04:17 AM
Last Post: Eugo
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 6,480 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 9,148 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 5,675 08-15-2022, 06:39 AM
Last Post: nemsys
  Share Folder On Windows Network? Peter Gamma 13 19,717 04-01-2022, 08:47 AM
Last Post: Peter Gamma
  Building an image with phosh liara 1 4,271 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 49,301 01-15-2022, 02:35 PM
Last Post: gilwood
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 4,220 11-01-2021, 09:00 AM
Last Post: e1337
