Focal Gnome 20.04 no sound?
Question
Today I noticed that @ayufan had a Ubuntu 20.04 build, so I decided to try it out. No matter what I do, however, I cannot get any sound from the speakers. I have tried everything I could find on this forum, and made sure that the speakers were turned up in alsamixer, but no luck. Ideas anyone? Other then no sound and the printing service missing (which I can live with) I have really been loving this build.
Have you run the postinstall script from the pbp-tools repo floating around?
That enabled sound for me, though it's still erratic after deep sleep (which needs the BSP uboot).
This worked for me based on the above pbp-tools hint and script:
Get https://gitlab.manjaro.org/manjaro-arm/p...ound.state and put it into /var/lib/alsa, then run alsactl nrestore
(06-22-2020, 09:03 PM)65a Wrote: This worked for me based on the above pbp-tools hint and script:
That looks just about what people did here manually: https://github.com/ayufan-rock64/linux-build/issues/435. I tried it that way and it worked great, but I am still going to try the above file because when I plug in headphones, the right side is louder then the left side (and no, it isn't just the headphones). On a different note, does sleep work in the Focal Gnome 20.04 build? When I tried to put my Pinebook Pro into sleep, it just put itself into a deep sleep and wouldn't come out of it, forcing me to do a hard reboot. Thanks for the tip!
You need the BSP uboot and the 5.7 kernel if you want deep sleep on Ubuntu 20.04.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,275 08-09-2025, 06:53 AM
Last Post: Sb2024
  Sound on Armbian Bram 1 4,328 04-01-2023, 03:16 PM
Last Post: TRS-80
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 9,112 11-02-2022, 02:33 PM
Last Post: kebab
  Loud distorted speaker sound when connecting to power supply myself600 2 3,963 09-21-2022, 12:11 PM
Last Post: myself600
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 7,735 08-21-2022, 12:00 PM
Last Post: u974615
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 3,736 02-18-2022, 12:59 PM
Last Post: ImmyChan
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 32,202 10-18-2021, 07:31 PM
Last Post: Syonyk
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 4,562 07-13-2021, 10:37 PM
Last Post: pjsf
Music No sound on PBP default installation ivek 9 17,685 05-09-2021, 05:58 PM
Last Post: binholz
Rainbow Armbian Groovy/Bullseye with Gnome clover 10 20,902 12-27-2020, 04:10 PM
Last Post: bus-error
