Official Debian release won't boot!?!
SBC:    Rockpro64 v2.1 4Gb
OS:    Official Debian Release (un-bootable)
So I decided to try the Official Debian release on my RockPro64
and the installation went fine but would not [re]boot after the
installation.
Any ideas, recommendations, suggestions?
TIA,
/Faradn
~ Rockpro64 ~ Odrooid C4 ~ Odroid N2 ~ Odroid XU4 ~ Pi 3B ~
(06-13-2020, 03:07 PM)Faradn Wrote: SBC:    Rockpro64 v2.1 4Gb
installation.
TIA,
/Faradn
We must copy some files from an ayufan image.
Here an thread on my private forum (only german)
https://forum.frank-mankel.org/topic/831...n-bullseye
We need from boot partition:
folder dtbs
folder efi
folder extlinux
And we must edit extlinux.conf
After this Debian Bullseye is running fine Smile
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
In my experience, the official installer in unstable does not install the bootloader yet.
If you have flashed the bootloader to SPI, you only need to take care of extlinux.conf and the dtb files (the EFI stuff is imho not needed) as described by Bullet64.
If you don't have the bootloader in SPI, you have to manually build and flash the bootloader to your sdcard.
=> As of now, installing Debian unstable using the official installer does not work as intended yet. I can't recommend it for end-users.
(06-20-2020, 05:32 PM)kuleszdl Wrote: In my experience, the official installer in unstable does not install the bootloader yet.
Thanks for your comment.
We aren't end-users Big Grin
3. RockPro64 v2.1
So, i have done some testing Wink
It boots from
  • PCIe NVMe SSD
  • PCIe SATA ASM1062
  • USB2
  • USB3 **only Samsung SSD T5** boots
We can use normal installation or installation with LVM and password protection.
The fan is rotating too. Big Grin
I am only testing minimal installation, no interest in desktop on SBC.
3. RockPro64 v2.1
  Freezes and kernel panics with Debian trixie jssfr 4 4,114 04-15-2026, 06:48 PM
Last Post: prahal
  Boot/Shutdown on timer captainmorgan 8 16,262 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,486 08-16-2023, 01:34 AM
Last Post: varac
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 6,972 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,067 04-23-2023, 11:02 PM
Last Post: Thisone
  RockPro64 boot questions misterc 3 6,831 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,144 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 3,083 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 6,567 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 6,388 01-06-2022, 03:09 AM
Last Post: susy1075
