Pine64 Linux fixup script
I am a friend of pragmatic solutions, so here is a very simple one to handle current and future fixes required on Pine64 without having to provide packaging.
So there is now a script which can be run on any Pine64 (Linux) any time, multiple times. The script will fix whatever needs fixing. Thus the script is called "pine64_fix_whatever.sh". The idea is that whenever some issue comes up, a solution can be added to this script, run it again and be good.
Fixes (in the order as they have been added):
- Pulseaudio stuttering by disable timer-based audio scheduling
The script is part of my platform-scripts at https://github.com/longsleep/build-pine6...rm-scripts.
You can simply run it like this on all Linux images (as root):
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh)
And reboot afterwards.
(04-23-2016, 03:48 PM)longsleep Wrote: I am a friend of pragmatic solutions, so here is a very simple one to handle current and future fixes required on Pine64 without having to provide packaging.
I've wondered for a while now why some people favor this syntax over the simple, old-style pipe, e.g.,
curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh | bash
Functionally, they're the same, and connecting processes with a pipe "|" doesn't make the shell mess with named pipes; it also isn't whitespace sensitive, while <(...) is, leading to possible error and confusion.
(04-23-2016, 06:55 PM)patrickhwood Wrote: I've wondered for a while now why some people favor this syntax over the simple, old-style pipe, e.g.,
I do not know reasons for other people but my reasons are simple - people cannot type the | easily on many international keyboards. Also there are tons of articles which say that you should not pipe curl into bash with the | example and as this is an end user forum i chose not to irritate Smile - After all these scripts are for users who do not care what actually is done.
Big Grin
I didn't think about the problems of finding | on some keyboards.  My ASCII-centric bias is showing through, I'm afraid.  I wonder how people write bash scripts if they don't have a $ key.  Maybe the Euro symbol works as a substitute Big Grin
I'm guessing the articles about piping curl into a shell you mention are of the "don't run random shell scripts off the internet" variety.  Not bad advice, actually, although this (and wget) shows up all over various official installation guides.  Here's one for installing Docker from docs.docker.com: curl -fsSL https://get.docker.com/ | sh
  Programming languages support under PINE64 baryluk 6 20,431 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,288 03-28-2020, 06:20 PM
Last Post: ty1911
  Manjaro arm on pine64+ roel 2 10,501 10-19-2019, 05:13 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 95,186 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,127 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,590 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Volumio for PINE64 Released mikelangeloz 11 38,532 03-22-2019, 09:25 AM
Last Post: llungster
  Gentoo Linux test image xalius 23 72,170 01-28-2019, 11:05 PM
Last Post: necrose99
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,571 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 9,953 01-04-2019, 03:47 PM
Last Post: Max11
