Soldering internal Wifi/Bluetooth antenna
just did a complete disassemble of my Pinebook Pro. When I tried to disconnect the internal wireless antenna from the CPU Board the socket came off from the board, damage caused. Would like to repair without replacing the CPU Board, are there two potential solder joints (shield/signal) where the antenna can be soldered to ? If it cannot be fixed...USB Wireless dongle seems to be the remaining option.
Any hint appreciared, Peter
(06-18-2020, 08:44 AM)petet0n76 Wrote: Hello,
Sorry to knows about antenna socket comes off. You can directly solder to the PCB soldering point but needs good study hand and soldering skill.
  Kernel Not Detecting Wifi tallfrye 10 8,701 01-01-2024, 06:57 AM
  Connection to WiFi with OWE IhorOlkhovskyi 1 4,030 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 18,914 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 3,245 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 5,800 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 3,109 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 7,325 03-29-2021, 06:57 AM
Last Post: barray
Lightbulb Bluetooth headsets - what works? embhorn 17 38,832 03-22-2021, 11:45 PM
Last Post: ab1jx
  Curious about problem with PBP Wifi kendew 3 8,537 01-14-2021, 11:16 AM
Last Post: clover
  Bluetooth microphone not detected mjc 2 7,218 10-31-2020, 01:34 PM
Last Post: wrzomar
