Android ( Stock or TV version ) rooted image please !!!
Wink
Hello everyone and good morning from Spain.
 I recently bought the Rock64 board and I would like to install the most recent and updated version of Android (Stock or TV) BUT it includes "root". That once installed, it is already with the "root" applied.
I want to install some applications BUT it is essential that the Android version is "root".
What is the LAST or most RECENT version of Android (Tv or Stock) that includes "root" and that is available for eMMC 16Gb?
Thank you very much and much encouragement, strength and courage Smile Smile
Looks like none of the current Android imgs come with root ootb, but you should be able to install Android and manually install root.
(06-17-2020, 06:07 AM)tophneal Wrote: Looks like none of the current Android imgs come with root ootb, but you should be able to install Android and manually install root.
Thank you.  Any tutorial or beginner's guide on how to root my device (Rock64) with the latest version of Android Stock or the latest version of Android TV?  Please, as easy as possible.  Thanks again.
(06-17-2020, 08:42 AM)AngelfromSpain Wrote: Thank you.  Any tutorial or beginner's guide on how to root my device (Rock64) with the latest version of Android Stock or the latest version of Android TV?  Please, as easy as possible.  Thanks again.
terribly sorry! I misread your OP, and thought you had a RockPro. With a Rock64, you have several options: https://wiki.pine64.org/index.php/ROCK64...e_Releases
The links don't work anymore. Sad Anywhere I can download them still?
Looks like you're 100% right, all those links are dead now. They're also dead on the new documentation pages, but if you go and click on the dead link of the img you'd want, there is a simple form to request the file to be reuploaded. perhaps that, albeit with some waiting, will get the imgs reuploaded and the links working again.
https://pine64.org/documentation/ROCK64/...s/#android
  Android Images (ROCK64) pineadmin 77 245,266 11-18-2024, 08:21 AM
Last Post: reukiodo
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,636 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,793 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,812 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,515 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,690 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,345 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,612 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,974 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 16,286 09-09-2020, 08:44 AM
Last Post: BowerR64
