Ayufan's Ubuntu Focal Gnome (20.04)
#21
(06-11-2020, 10:47 AM)clover Wrote: I have my focal gnome on eMMC. i use it almost daily to test PureOS pinephone software. love this image it rocks. perfect for my workflow.
Can you please how did you flash it to the eMMC?
I would like to flash Bionic MATE to mine. Smile
#22
(06-11-2020, 12:34 PM)cefre00 Wrote: Can you please how did you flash it to the eMMC?
Nothing special I think, boot from sd card, download the image. unzip.
sudo dd if=whatever.img of=/dev/mmcblkblah bs=1M status=progress
let it copy, power off computer, take sd out, power on and it should boot from emmc.
#23
I see, thank you! Wink
Let me ask you how important is the proper block size in DD? For some of the IMG-s I saw even 16MB as a block size, thought sometimes I see 1M or even less.
Just out of curiosity. Can I ruin an IMG on my SD selecting a wrong BS?
EDIT:
Again I could not boot from the eMMC, so I went ahead and installed Bionic MATE and to my honest surprise it worked! Big Grin
Now I see bunch of issues here or there like very annoying screen flickering, but with that I'll check the other threads. Thanks for the help! Wink
#24
I'll try that next time. But first I'd need to get it to boot something, anything at all. Right now it doesn't boot eiter eMMS or SD-card.
#25
Actually, I just got in the USB eMMC thingie, which makes things soooo much easier. Just put your eMMC on it, stick it in you desktop  and use Etcher to flash the image. Put it back in the PBP et voila...
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,238 08-09-2025, 06:53 AM
Last Post: Sb2024
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 7,724 08-21-2022, 12:00 PM
Last Post: u974615
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 3,727 02-18-2022, 12:59 PM
Last Post: ImmyChan
  soft brick with ayufan DimHummingbird 9 15,188 07-18-2021, 02:58 PM
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 4,546 07-13-2021, 10:37 PM
Last Post: pjsf
  After update in Ubuntu bionic mate system crashed Wawe 2 7,342 04-18-2021, 04:52 AM
Last Post: Wawe
Rainbow Armbian Groovy/Bullseye with Gnome clover 10 20,828 12-27-2020, 04:10 PM
Last Post: bus-error
  Ubuntu Installation on PBP narinderpal10 5 12,288 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,722 12-15-2020, 01:53 AM
Last Post: BryanF
  Best Gnome distro for PBP? Upokupo 2 7,215 11-26-2020, 11:51 AM
Last Post: clover
