Slow ethernet in linux
Hi, I do have the same problem. I am getting around 1MB/s, with 2MB/s peak (wget -O /dev/null from internet for specific big file), when on other computer on the same network I am getting 30-45MB/s, and maybe 90MB/s during good time of a day. I will probably do some testing on local network strictly, but I done some ssh tests, and it isn't looking pretty.
Forcing to 100 autoneg off using ethtools, make it even worse. I am getting 50-100KB/s! Forcing to 1000 autoneg off makes it do not work at all.
ip -s l shows no errors:
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 7a:6e:63:xx:xx:xx brd ff:ff:ff:ff:ff:ff
RX: bytes packets errors dropped overrun mcast
2277867123 3481188 0 0 0 0
TX: bytes packets errors dropped carrier collsns
6628900774 4981672 0 0 0 0
In dmesg I do see a lot of these errors, every few seconds, especially during heavy network use
[21189.979887] RTL871X: nolinked power save leave
[21191.275452] RTL871X: nolinked power save enter
Ok. Somehow magically it improved.
echo on > /sys/class/net/eth0/power/control
made me able to copy data over ssh from other Linux box (capable of easily doing 100MB/s), with about 22MB/s (tested using 1.2GB file using dd bs=64k from sshfs file).
I turned it back to auto:
echo auto > /sys/class/net/eth0/power/control
and it shows now 25.6MB/s
Not bad.
(04-23-2016, 03:11 PM)baryluk Wrote: Hi, I do have the same problem. I am getting around 1MB/s, with 2MB/s peak (wget -O /dev/null from internet for specific big file), when on other computer on the same network I am getting 30-45MB/s, and maybe 90MB/s during good time of a day. I will probably do some testing on local network strictly, but I done some ssh tests, and it isn't looking pretty.
Not bad.
Hi, I have same issue as you, with autoneg on, i have only 3-5kb/s 100mb autoneg off 100 improved it to 120kb/s, and autoneg off 1000 is not working at all
i tried echo on > /sys/class/net/eth0/power/control as you suggested, but its not chaning anything, probably not related to the issue. did you change anything else in the meantime?
can you tell me what kernel do you use?
pine64user@debianpine64:~/Downloads$ uname -a
Linux debianpine64 3.10.65-5-pine64-longsleep #19 SMP PREEMPT Fri Apr 15 19:55:17 CEST 2016 aarch64 GNU/Linux
do anyone know working fix for terribly slow ethernet?
(04-23-2016, 03:11 PM)baryluk Wrote: made me able to copy data over ssh from other Linux box (capable of easily doing 100MB/s), with about 22MB/s (tested using 1.2GB file using dd bs=64k from sshfs file)
So you did not test network speed but CPU encryption performance instead. Why exactly?
to test the actual speed, i would rather use speedtest_cli
sudo wget https://raw.github.com/sivel/speedtest-cli/master/speedtest_cli.py sudo chmod a+rx speedtest_cli.py ./speedtest-cli
where i have 2Mbit/s, which, for some reason is 2-4x more than any wget command (60-120kb/s)
on the other host, speedtest result is 120Mbit/s  Angry
(04-28-2016, 12:55 PM)piahoo Wrote: to test the actual speed, i would rather use speedtest_cli
Also wrong Smile
You should try to isolate problems. Get iperf/iperf3/netperf and test between machines on the LAN.
Regarding the many reports of really slow Ethernet performance I still wonder whether that's not in reality 'Internet performance' instead (maybe caused by mismatching MTU settings between Linux kernel running on Pine64 and the router -- it's known that Allwinner's BSP Ethernet driver is somewhat crappy -- at least not tested that much).
I tested ssh, because I had no time to setup unencrypted local server of any kind. The information is still useful. Also during the test non of the cores hits 100%, so I wasn't exactly CPU constrained I think. Maybe some issues with IRQs.
I also said that I used wget over unencrypted http from internet (and mind you I do have 1Gbps internet and router capable of doing that, with others computer hitting 90MB/s for the same big file download).
I do not know what I have done, but playing with power/control file made it faster. I will reboot the board and see if it is slow again.
using netperf and multiple streams, courtesy of the wrapper script: https://github.com/akhepcat/BettererSpeedTest
qdisc is not enabled:   root@p64:~# lsmod | grep ifb | wc -l   0   root@p64:~# BettererSpeedTest   2016-04-29 10:29:38 Testing against speedtest (ipv4) with 20 simultaneous sessions while pinging oldspeedtest (30 seconds)   ...............................    Download:  942 mb/s     Latency: (in msec, 31 pings, 0.00% packet loss)         Min: 0.306       10pct: 0.325      Median: 0.772         Avg: 1.032       90pct: 1.970         Max: 2.460   ...................................      Upload:  575 mb/s     Latency: (in msec, 24 pings, 0.00% packet loss)         Min: 0.414       10pct: 0.424      Median: 42.400         Avg: 58.657       90pct: 137.000         Max: 253.000
And then I enable qdisc, via custom wrapper script:
  root@p64:~# tc qdisc show   qdisc htb 1: dev eth0 root refcnt 2 r2q 625 default 11 direct_packets_stat 0 direct_qlen 1000   qdisc fq_codel 8002: dev eth0 parent 1:11 limit 10240p flows 1024 quantum 300 target 5.0ms interval 100.0ms   qdisc ingress ffff: dev eth0 parent ffff:fff1 ----------------   qdisc htb 1: dev ifb0 root refcnt 2 r2q 625 default 11 direct_packets_stat 0 direct_qlen 32   qdisc fq_codel 8001: dev ifb0 parent 1:11 limit 10240p flows 1024 quantum 300 target 5.0ms interval 100.0ms ecn       root@p64:~# BettererSpeedTest   2016-04-29 10:31:54 Testing against speedtest (ipv4) with 20 simultaneous sessions while pinging oldspeedtest (30 seconds)   ..............................    Download:  505 mb/s     Latency: (in msec, 31 pings, 0.00% packet loss)         Min: 0.333       10pct: 0.365      Median: 0.457         Avg: 0.626       90pct: 0.546         Max: 5.740   ..............................      Upload:  845 mb/s     Latency: (in msec, 29 pings, 0.00% packet loss)         Min: 0.368       10pct: 0.416      Median: 0.750         Avg: 2.315       90pct: 2.820         Max: 26.500
as you can see, my queuing still needs some tweaking to get the download speeds to recover to pre-queuing speeds,
but the upload speeds are quite nice.
I recently added all the network scheduling modules to my Kernel configuration (https://github.com/longsleep/linux-pine6...99631139ce). Care to share your bootstrap script to setup qdisc?
#19
as mentioned in the readme, this was originally cribbed from the gentoo wiki,
and then i've extended it to make it easier for me to use.
https://github.com/akhepcat/qdisc
** followup **
If i only enable queuing on the upload side, my results are about 900d/800u mb/s, which is good enough for me. :-)
#20
netperf tests with standard pfifo_fast
$ netperf -H wielkiczarny.local -l 60 -t TCP_STREAM MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.00 695.63
$ netperf -H wielkiczarny.local -l 60 -t TCP_STREAM MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.00 702.86
$ netperf -H wielkiczarny.local -l 60 -t TCP_MAERTS MIGRATED TCP MAERTS TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.00 733.93
$ netperf -H wielkiczarny.local -l 60 -t UDP_STREAM MIGRATED UDP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo Socket Message Elapsed Messages Size Size Time Okay Errors Throughput bytes bytes secs # # 10^6bits/sec 212992 65507 60.00 101426 0 885.87 212992 60.00 4087 35.70
$ netperf -H wielkiczarny.local -l 60 -t UDP_RR MIGRATED UDP REQUEST/RESPONSE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo : first burst 0 Local /Remote Socket Size Request Resp. Elapsed Trans. Send Recv Size Size Time Rate bytes Bytes bytes bytes secs. per sec 212992 212992 1 1 60.00 8486.10 212992 212992
$ ip l show dev eth0 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000 link/ether 7a:6e:63:xx:xx:xx brd ff:ff:ff:ff:ff:ff
Still It is unclear to me why wget from Internet is pretty slow at ~4-6MB/s, and maks 10MB/s at the start of download.
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,544 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 96,616 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,388 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,809 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 73,411 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,952 12-06-2018, 01:14 AM
Last Post: tenspd137
  Real-time linux kernel Artyom 45 125,048 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 10,436 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,229 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 6,759 08-03-2017, 10:05 PM
Last Post: pfeerick
