20160303 Download Links Hanging
When I try to download any of the 'Android Image Release 20160303' images from here, the site just hangs. Are other people experiencing that? Does anyone know of any other mirrors/torrents for these files (preferably the DD image). Thanks!
I'm getting the same thing. It times out on me too.
Okay, good--I'm not crazy!
Same here as well
I am also having this problem Sad
We will check out.
(04-24-2016, 02:51 AM)tllim Wrote: We will check out.
I can now download the file but the checksum does not match the wiki. Twice now I've downloaded and found the checksum to be 2abdf3578a50e2df2c3e33b8e61c80c9. Should the wiki be updated?
(Edit: Correct checksum. I originally left off the final 9, h/t to androsch for catching that)
(04-24-2016, 09:45 AM)highmileage Wrote: I can now download the file but the checksum does not match the wiki. Twice now I've downloaded and found the checksum to be 2abdf3578a50e2df2c3e33b8e61c80c. Should the wiki be updated?
Can confirm the checksum for the zip is as stated above (plus a final 9), for the extracted image its also different from the wiki, so can someone kindly check and update the wiki or correct the file?
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
So against my better judgement I decided to just burn this image and see what would happen.
Note: For anyone trying to unzip this image on OSX (I was on 10.11.4), you might get caught in a zip to cpgz loop. I did multiple times, despite downloading via different browsers in an attempt to mitigate the problem. After jumping on my linux machine, downloading, and unzipping, I was able to successfully burn this image. I was then able to successfully boot up Android on my Pine.
Good:
-Things feel much faster than the Ubuntu image I was previously on.
-Able to link to Google Account
-The native browser worked immediately--like gtpboy, I had to uninstall and reinstall Chrome to get it working.
-YouTube videos play successfully via the browser and app--YouTube playback was total garbage on the Ubuntu image I first used.
Bad:
-At first I was getting errors in the play store that I ultimately remedied by following these instructions. Picture below:
[Image: 20160424_151709.jpg?raw=1]
-Everything feels really large on my display--I wish I could change the resolution to be a bit smaller.
-I had speakers hooked up to the Pine and it was outputting via them but upon reboot it started outputting through the TV again--potentially an issue depending on your audio setup and if you want to use this as a media center.
Questions:
-Anyone have experience with running Android on a display like this? Is it normal for everything to look so comically large? I'm used to Android on a phone but this is my first time ever running it on a larger monitor.
-Is anyone really happy with their Linux install? This Android install is fun but I don't like not have access to a terminal or common shortcuts I'm used to using.
TO DO:
-Figure out how to get Android to see all 64GB--right now it only seems to be aware of 4.57GB
For the curious, my setup:
Pine A64+ 2GB board, wifi + Bluetooth module just ethernet.
64GB Sandisk Extreme Plus UHS 3 microSD card w/ Android Release 20160303 (dd zipfile checksum: 2abdf3578a50e2df2c3e33b8e61c80c9)
Asus charger that shipped w/ the original Nexus 7 (2012)
Costco HDMI Cable connected to Samsung 27" 1080p LED display
Old USB Optical Mouse via an Old USB Keyboard
(Logitech bluetooth mouse later up and running)
(04-24-2016, 04:31 PM)highmileage Wrote: TO DO:
The only known way for Android to see the entire 64GB at the moment is to use PhoenixCard on Windows.
I am currently trying to figure out if expanding the data partition is possible on linux, but for OS X, there is totally no luck with that (no ext4 support).
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
  how to download AOSP and BSP awaysu 1 5,429 09-05-2017, 01:36 AM
Last Post: awaysu
  Reducing Android Image download size. KPhillisJr 4 12,944 08-21-2017, 04:48 AM
Last Post: winstongel
  I can get Internet Connection, However I cannot download APK File (Kitkat and Lollipo deniyulianti 0 3,622 10-15-2016, 07:28 AM
Last Post: deniyulianti
  Can't download apps off Google Play! Bacon Strips 6 13,930 08-31-2016, 12:26 PM
Last Post: DonFL
  Where will system images be hosted for download? samandiriel 17 40,802 07-14-2016, 04:57 PM
  Extremely slow image download willyfog 9 19,121 06-27-2016, 08:46 AM
Last Post: lennychuck
  Android 5.1.1 Image 20160505 wiki links kinbeowulf 7 14,481 05-11-2016, 04:05 AM
Last Post: Terra854
  Can't download Android Images anddev 1 5,267 04-26-2016, 06:10 PM
  *UPDATE* First Impressions of Release 20160303 and App Compatibility List gtpboy 20 41,045 04-22-2016, 04:45 PM
Last Post: g_t_j
