Switch Fn and Ctrl keys
I've been enjoying my PBP for the past week but I've been wondering if it was possible to switch the Fn and the left Ctrl keys? I've found a few options in the Keyboard->Advanced section but nothing on the Fn key.
(06-06-2020, 11:18 AM)adria Wrote: I've been enjoying my PBP for the past week but I've been wondering if it was possible to switch the Fn and the left Ctrl keys? I've found a few options in the Keyboard->Advanced section but nothing on the Fn key.
I'm going through trying to remap some keys right now myself!
You probably want to use `xmodmap` in the terminal. `man xmodmap` has a few examples of swapping keys.
Check out this guide:
https://wiki.manjaro.org/index.php?title...ard_Layout
I decided I wanted to install xev (pacman -S xorg-xev) to see what the keycodes are. But I had to update my mirrors before it would let me do that.
That looked like this:
1. `pacman -f` (this took a really long time)
2. `pacman -Syuu` (to update pacman with the new mirrors
3. `pacman -S xorg-xev` to actually install the thing
Nice, thanks. I'll read through the manual of xmodmap. I'm not sure what you mean by your first pacman command. `-f` does not exist and `-F` needs a target.
you could also go nuclear and change via the firmware
  Dead Pinebook Pro Keyboard Keys calinb 2 4,521 09-02-2023, 12:31 PM
Last Post: calinb
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 6,739 04-23-2023, 06:58 AM
Last Post: acruhl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,083 10-19-2021, 01:57 AM
Last Post: j4n3z
  Pinebook Pro not powering on when eMMC hardware switch is off vgrimaldi 2 5,665 06-29-2021, 05:19 AM
  Taming the power switch? ab1jx 4 12,104 11-30-2020, 10:57 PM
Last Post: rimaille
  Pine Key + Backspace/Arrow Keys not registering tslight 3 8,109 06-13-2020, 11:31 PM
Last Post: xmixahlx
Bug How about a hard power switch? + crash report Dendrocalamus64 7 16,977 05-24-2020, 04:03 PM
Lightbulb Are you like me and can never remember the privacy keys? jabo 2 5,987 03-16-2020, 09:28 PM
Last Post: LittleWalter
  Trackpad Switch primary/secondary buttons and paste on double-tap? lowry 0 2,845 01-21-2020, 07:21 AM
Last Post: lowry
