Minimum requirements for ROCK64 Android install?
I would like to install Android (at least 7.1.2, not Android-TV) on ROCK64.
What would be the minimum RAM size and SD card size requirements for doing this?
Can I get by with 1GB RAM version of ROCK64 and 8GB SD card?
The setup can and need be quite minimalist, as I will only need to run a handful of very simple apps. Google Play Store is not required for my use case.
For reference - When I ran these apps on an Android 5.1.1 emulator set to 1GB RAM, I had over 325 MB of free RAM; and only 26% of 8 GB storage was used.
            - Similarly, these same apps ran fine on an Android 7.1.1 and Android 10 Virtual Devices in Android Studio, both set to 1 GB RAM, 8 GB storage.
  rock64-android10-tv patchset for Firely AlexS 1 823 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 247,208 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,560 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,863 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 12,025 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,977 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,669 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,828 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,521 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,754 09-18-2020, 08:12 PM
Last Post: BowerR64
