extracting debian to SD
is it possible to extract the debian image to an SD card using the pinebook majaro?
You should be able to write the image to your SD card using dd, e.g.
# sudo dd if=debian.img of=/dev/mmcblk1 bs=64M status=progress
Exclamation  Make sure your SD card is actually at /dev/mmcblk1!
  Use SD to install new OS over pinebook debian Rudy558 10 30,227 03-09-2025, 11:17 AM
Last Post: davisthomas
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 498,084 05-12-2023, 06:09 AM
Last Post: korreckj328
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 2,611 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Main Stream Debian on Pinebook Pro ? bcnaz 4 7,467 08-22-2021, 09:11 AM
  Audio with Debian GloriousCoffee 5 13,045 10-15-2020, 01:22 PM
Last Post: Mangled
  help on setting up debian (or ubuntu) on micro sd card pine76 2 12,083 09-17-2020, 05:10 PM
Last Post: bcnaz
  Suspend with NVME not working - Default Debian appdev46 5 15,470 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 13,715 05-26-2020, 07:21 AM
Last Post: User 6582
  Possible Software To Debian PBP From Debian Intel jcj52436999 1 4,505 04-28-2020, 06:15 AM
  Pinebook pro random reboot default Debian tso4ev 3 8,099 02-04-2020, 06:30 PM
Last Post: Baldnerd
