Power indicator LED flashing alternating colours
Sad
I've been messing around with my brand-new Pinebook Pro. I had an issue where KDE appeared to have died, so I force shutdown the laptop. After that, I could no longer log in - my password would get accepted, but it would hang on the progress bar after the password.
To try and work out what's going on, I dropped into tty2 (Ctrl + Alt + F2), but then I realised that things are seriously wrong - I would get segfaults running man. I force shut down the laptop again, and now I'm getting the power LED flashing.
I am fully aware that this is my fault (well, except the initial KDE blackout which I probably should have debugged more), however, does this mean that eMMC is now corrupted and the only solution is a reinstall?
Also, I don't know what the colours of the power LED are as I'm colourblind, but I'm certain people in the know understand what I'm talking about. I think the error codes should also possibly be on the wiki - I'm happy to add those there when I get a reply here.
I assume you have no data on the PBP that you want to restore.
In that case just try to reinstall.
Typically the LEDs alternating between green and amber indicate a kernel panic.
(05-30-2020, 12:46 PM)tophneal Wrote: Typically the LEDs alternating between green and amber indicate a kernel panic.
That's useful information, however, it makes me a bit worried - currently, I'm trying to run Manjaro 20.04 XFCE (the microSD variant) and get reproducible green/amber flashing indications straight after log-in. I will try other distros/etc, but at the moment my PBP is not a happy lappy. Sad
  Pinebook64 Pro doesn't power on andrea_from_italy 9 9,273 03-20-2025, 10:07 AM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,950 01-16-2024, 09:17 AM
Last Post: jbradley419
  Lockable-until-power-cycle persistent storage Melab 0 2,758 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 3,041 07-20-2023, 11:06 PM
Last Post: papable
  Blinking Tiny Blue Indicator Light? ArchiMark 3 4,930 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  When does Pinebook Pro power LED go on? Bram 0 2,702 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 5,517 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 4,243 02-21-2023, 02:31 PM
Last Post: Idaho
  Unable to boot from emmc after flashing it rfm83 3 6,398 11-08-2022, 10:59 PM
Last Post: rfm83
  After Flashing eMMC, Will Not Boot Mossbot 5 7,299 09-28-2022, 06:22 PM
