Phone dead.
OK, I charged the phone up for the first time and was able to turn it on and after a while it went dead.
Tried to recharge it but no indicator light to say its charging.
Any ideas?
Thanks.
Sent from my LYA-L09 using Tapatalk
have you looked at the posting further down re charging etc
or here
https://forum.pine64.org/showthread.php?tid=9105
(05-22-2020, 09:28 AM)colin hodsdon Wrote: have you looked at the posting further down re charging etc
or here
I'll take a look.
Thanks.
Well, I've tried to reset the phone and used a different USB cable but seems the phone is completely dead.
I'm really peeved off with pine that I paid for a phone that stopped working within the hour of switching on for first time.
Did you only ever get it to turn on when plugged in? Sounds like maybe you didn't remove the battery isolator tab.
....  In the past,  phones often came with the battery not installed,  but packed inside the same box as the phone
   Have you removed the battery isolation tape from the phone ?    (Carefully !)
I noticed the phone is not charging on the computer or other cheap wall chargers. Be sure you use a powerful one (I only can charge it in the UPS). I think I read your charger has to be at least 3V.
the USB spec is 5 volts, so no charger should ever be less than 5 volts. the only variance should be in amperage, which varies by USB spec
  Default password for KDE plasma pine phone Toni 0 7,802 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 4,016 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 2,707 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 3,574 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 5,650 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 7,824 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 11,453 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,021 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 4,141 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 15,243 09-01-2023, 04:26 AM
Last Post: gregb49
