Netflix, state of the art?
#51
(05-07-2020, 03:48 AM)Eight Bit Wrote: Though maybe obvious, I had to try ^ ^
The Alsamixer DAC audio output of Chromium-armhf doesn't route to a connected bluetooth headset either.
I can easily have Chromium play spotify through the speakers while listening to a youtube from firefox through a headset.
It's not a bug, it's a feature! Smile
LOL!!!
Yes a feature for you :p
Someone on Manjaro forum have advices a fix for Volume controller to be used in Chromium-Docker
Here is the post
DE Volume Control Fix
I am testing it and then will see how I can get it included in the package so users can just upgrade the package to get it fixed.
Manjaro ARM Team.
Chromium Docker package updated to fix netflix-1080p plugin.
Manjaro ARM Team.
(05-20-2020, 10:25 PM)spikerguy Wrote: Chromium Docker package updated to fix netflix-1080p plugin.
Nice! Smile
I tested with Spotify and Netflix and runs nice! XD
I need little help reading this https://github.com/HenningThiemann/docke...mium-armhf
But runs... Tongue Tongue Tongue
i think it should be possible to get rid of docker completely using debootstrap.
I got google chrome running as follows:
mkdir deb
debootstrap --arch=armhf buster deb
cp deb/lib/ld-linux-armhf.so.3 /lib
sudo chroot deb /bin/bash
Now inside the chroot i edited /etc/apt/sources.list to enable non-free and contrib and then i was able to do apt update && apt install chromium.
Once this is done, one can launch chromium as follows:
LD_LIBRARY_PATH=$PWD/lib:$PWD/usr/lib/:$PWD/usr/lib/arm-linux-gnueabihf/:\
$PWD/lib/arm-linux-gnueabihf/:$PWD/usr/lib/arm-linux-gnueabihf/pulseaudio/ \
usr/lib/chromium/chromium
this is without docker or chroot or x forwarding ..
Here is my configuration of /usr/local/bin/chromium-armhf, with sound control (in Bluetooth too) :
#!/usr/bin/env bash
addrip="$(hostname -i | grep -v '127.0.0.1' | awk '{ print $1}')"
echo "Enabling XHost Forwarding"
xhost +local:docker
echo "Searching for Docker image ..."
DOCKER_IMAGE_ID=$(docker images -q hthiemann/chromium-armhf:latest | head -n 1)
echo "Found and using ${DOCKER_IMAGE_ID}"
docker run --rm --privileged \
-e DISPLAY=unix$DISPLAY \
-e PULSE_SERVER=tcp:${addrip}:4713 \
-e PULSE_COOKIE_DATA=`pax11publish -d | grep --color=never -Po '(?<=^Cookie: ).*'` \
-v chromium_home:/home \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-v /dev:/dev -v /run:/run \
-v /etc/machine-id:/etc/machine-id \
--ipc=host \
 ${DOCKER_IMAGE_ID}
If it helps anyone.
Smile
(05-31-2020, 08:41 AM)koparthur Wrote: Hi,
#!/usr/bin/env bash
xhost +local:docker
--ipc=host \
 ${DOCKER_IMAGE_ID}
If it helps anyone.
Smile
This needs paprefs with pulseaudio on network enabled right?
Nice I wanted to use something similar thanks for the code.
Manjaro ARM Team.
#!/usr/bin/env bash
xhost +local:docker
--ipc=host \
 ${DOCKER_IMAGE_ID}
If it helps anyone.
Smile
Yes, and you have to activate that in Paprefs (sorry it's in french) :
[Image: Screenshot_20200531_233954.png]
I activated the PulseAudio server (Papref) and modified /usr/local/bin/chromium-armhf, it works fine.
The only problem is that if the IPv4 of the PBP changes, the sound doesn't work anymore and you have to restart Chromium.
#!/usr/bin/env bash
xhost +local:docker
--ipc=host \
 ${DOCKER_IMAGE_ID}
If it helps anyone.
Smile
If IP changes then a restart is a must as even your internet will stop working. That is how dockers work Wink
Manjaro ARM Team.
(05-28-2020, 01:58 PM)kervel Wrote: Hello,
mkdir deb
Hey,
I just did this based on a systemd-nspawn container following the guides here:
Works pretty well and doesn't need a docker daemon running in the background. My scripts for integration in Manjaro:
Like this idea much better than the docker image approach...
  Funny Conky like script to monitor your PBP state as400 1 5,399 08-19-2020, 12:57 PM
Last Post: xmixahlx
  Netflix on default Chromium/Debian MoonDog 8 16,312 01-28-2020, 04:58 AM
Last Post: simeon
  State of hibernate or hybrid-sleep? Arwen 5 11,689 11-21-2019, 07:51 AM
