Native Xbox/wiimote support?
Any chance we could get native wiimote/Xbox controller support? I have an Xbox to USB adapter and would love to use it to play games without having to re-change settings after every upgrade
(04-20-2016, 09:12 PM)Abuthemagician Wrote: Any chance we could get native wiimote/Xbox controller support? I have an Xbox to USB adapter and would love to use it to play games without having to re-change settings after every upgrade
Just out-of-curiosity, did you by any chance get a wireless xbox controller working? sorry for not answering your question and posing a different one instead ...
No worries at all, I don't mind if this turns into a controller free for all. That saves having 30 posts about them. I only have a wired controller. I will try a wiimote with the app from the play store tonight as I have the wifi/BT module installed. Maybe someone else will see this that has tried the wireless controller
(04-21-2016, 09:04 AM)Abuthemagician Wrote: No worries at all, I don't mind if this turns into a controller free for all. That saves having 30 posts about them. I only have a wired controller. I will try a wiimote with the app from the play store tonight as I have the wifi/BT module installed. Maybe someone else will see this that has tried the wireless controller
So, did you give it a go? did it work ?
I had tried the wired Xbox 360 Controller and there are no Problems. Then i tried the Usb to wireless cable and he couldn't find the controller and then i tried the wireless hub for the controller. And it register the Hub but not the Controller.
This is so far my Report.
Pine 64 2GB Version
Pine64 Emulator Try
Android:
NES:
SNES: Super Retro 16| Controller works| Games 60FPS
GB/GBC:
GBA:
N64:
Ok, strange. I played around with RemixOS and had no problems with the wireless controller. Perhaps with the notable exception that after the controller syncs with the receiver it keeps blinking. But it works nonetheless
360 wireless controller (using the usb dongle) seems to work out of the box. The only problem is that the layout is totally wrong. Analog Triggers are switched with the right analog stick, also digital pad is not working at all. This destroys the experience with games that use both analogs.
Please add the correct keylayout for 360 controller and PS3/4 controllers (yes they are as mess too) in the next revision of android and remix os.
(05-04-2016, 02:06 PM)moondark Wrote: 360 wireless controller (using the usb dongle) seems to work out of the box. The only problem is that the layout is totally wrong. Analog Triggers are switched with the right analog stick, also digital pad is not working at all. This destroys the experience with games that use both analogs.
Regarding the 360 controller - Have you tried it under RemixOS ? which version?
Yes I tried under Remix OS 2.0 20160415 image. On android I found the same problem regarding the wrong key mapping.
  Continued support? EricL 9 21,046 08-17-2017, 02:39 PM
Last Post: dkryder
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,172 12-19-2016, 07:49 PM
Last Post: Toriless
  UVC Support Thois 1 6,461 09-19-2016, 10:51 PM
Last Post: mikey0000
  Remix touch screen support Danbrack 3 14,066 07-24-2016, 11:20 PM
Last Post: pinkelephants
  Official touchscreen support baumbachandrew 1 4,828 07-12-2016, 11:27 PM
  How do we get support for incompatible apps in the play store Abuthemagician 7 13,258 04-22-2016, 07:44 AM
Last Post: Tarjei85
