Cheap 4-port SATA card working with RockPro64 4Gb
.png   OMV.png (Size: 57.75 KB / Downloads: 1,012)
Just a small post to report some success with a cheap 4-port SATA card on the Rockpro64
Big Grin
https://www.amazon.ca/Ziyituod-Controlle...5WRVNV0WZ8
It works with Ayufans 0.9.14 minimal, and with StretchOMV (Stretch) - with armhf variants.
All ports work. For testing I have a 4Tb Seagate, and 2 x 3Tb Seagate in RAID5. There is also a 2Tb drive not in the array.
(Card mode switch is set to AHCI boot)
For individual disks, under Debian using hdparm -Tt /dev/sdX, I was getting >100mb/s.
I will update when the array has finished syncing.
hdparm -Tt /dev/md0
/dev/md0:
 Timing cached reads:   2026 MB in  2.00 seconds = 1013.04 MB/sec
 Timing buffered disk reads: 830 MB in  3.01 seconds = 275.87 MB/sec
Not bad for a little SBC.
Tongue
Thanks,
Andy
I've made a rockpro64 device compatibility page.
Please update it with your successes/failures.
https://wiki.pine64.org/index.php/ROCKPr...patibility
If yours has a ASM1062 chipset, then I guess I have basically the same card (I already had added it to the Wiki). At least from the outside it looks the same.
Nice to hear that yours works with several disks attached, feel free to add this to the wiki.
Indeed it is.
root@shyguy:~# lspci
00:00.0 PCI bridge: Device 1d87:0100
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
root@shyguy:~#
root@shyguy:~# uname -r
4.4.190-1233-rockchip-ayufan-gd3f1be0ed310
Model number is SU-SA3004.V2
Only pci-e X1, but seems to be working just fine.
Thanks,
Andy
Cool. I see there is a 6-port version as well, wonder if it's workable (the card looks like it would fit to me, but maybe I'm wrong)
Are these 2.5" disks? 3.5"? spinning or SSD? all running off the stock power supply?
I could see setting one of these up myself. I've been wanting to set up a NAS machine and would love to do it with a PINE64 device. Preferably with some manner of RAID, mdadm would be fine at home.
it doesn't get happy
it doesn't get sad
it just runs programs
(08-01-2020, 05:38 PM)zer0sig Wrote: Cool. I see there is a 6-port version as well, wonder if it's workable (the card looks like it would fit to me, but maybe I'm wrong)
Hi, i use an PCIe SATA-card with JMicron JMS585- Chip. It has 5 ports. I am using this as an NAS.
2 * 2,5 Zoll as RAID1
2 * 3,5 Zoll as RAID1
Port 5 2,5 Zoll SSD with sys
u-boot in SPI and it boots from port 5
root@NASrp64:~# uname -a
Linux NASrp64 5.6.0-1137-ayufan-ge57f05e7bf8f #ayufan SMP Wed Apr 15 10:16:02 UTC 2020 aarch64 GNU/Linux
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Thanks,
that is very helpful.
Will check out this other forum.
it doesn't get sad
  Powering two disks from RockPro64 some_pinephone_user 3 6,051 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,760 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 14,403 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 10,760 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 4,456 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,625 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,324 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 3,180 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,357 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 49,152 12-18-2022, 06:25 PM
Last Post: heyghoge
