pmos ( phosh really) 04/10
very nice ,it seems to be more definite in operation ,responding to touch etc .,few extra apps (nice).
it shows Terminal in the list of installed apps , BUT no icon appears ?  (again ).
  the link also ,does not identify what you are downloading   plasma/phosh/gnome ?
What.... are you talking about?
The terminal shows but there is no icon? What?
And what link are you talking about? If you're talking about the images here, it literally has the UI right in the file name.
I think they mean this issue. And yes, in your link the image file name is pine64-pinephone-20200410.img.xz which does not literally have UI right in the file name.
Oops, I forgot to include the phosh name in the image filename...
The terminal not showing up is an issue in phosh itself. hasn't been fixed yet. Current workaround is installing gnome-terminal.
There will be a new image pushed Soon™ which has a 5.6 kernel, I'll add both terminals to that one.
(04-11-2020, 11:45 AM)PureTryOut Wrote: What.... are you talking about?
http://images.postmarketos.org/pinephone...410.img.xz
like this.
Icon Name Last modified Size Description
[PARENTDIR] Parent Directory -
[ ] pine64-pinephone-20200410.img.xz 2020-04-10 10:14 321M postmarketOS Disk image
[ ] pine-pinephone-20200316-phosh.img.xz 2020-03-16 12:07 288M postmarketOS Disk image
[ ] pine-pinephone-20200228-plasma.img.xz 2020-02-27 18:48 378M postmarketOS Disk image
[ ] pine-pinephone-20200228-phosh.img.xz
(04-11-2020, 02:49 PM)MartijnBraam Wrote: Oops, I forgot to include the phosh name in the image filename...
Thanks , just pointing it out , no big deal.
nicely done, thanks for all you do
Huh interesting, I did not see that image listed on the page I linked. Guess that's my mistake then, sorry.
And with no icon you mean there is no entry for the terminal at all then, not even the text. That is indeed a known bug, but I thought you were talking about something new.
is it required to flash the image to the sd or can we just use apk update && apk upgrade?
(04-14-2020, 06:08 PM)someGermanGuy Wrote: is it required to flash the image to the sd or can we just use apk update && apk upgrade?
i think if you use apk update && apk upgrade -y   ,you still need to flash the image ocasionaly to get anything in the read only portion updated.
 i feel sure someone with more knowledge will put us right .
 i split it up and ," apk update ", so i can see/ or list  what is being updated, then run "apk upgrade ".
someEnglishGuy   here
We don't have a read-only partition, so "apk update && apk upgrade -a" (note that -a switch) will always get you the latest available. No need to reflash the image.
Quote:i split it up and ," apk update ", so i can see/ or list what is being updated, then run "apk upgrade ".
Actually, you can just run "apk upgrade -i" (the -i switch) to see what is getting updated before you actually update.
  [Phosh] : Nheko and gnome-keyring freelectro 1 2,201 12-17-2024, 04:46 PM
Last Post: zeb11
  Fresh install pmos+phosh does not boot user641 1 3,185 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 11,336 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,277 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 8,027 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 13,482 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 3,294 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 5,729 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 13,533 02-03-2022, 09:14 PM
Last Post: parry
  Application list PMOS-Phosh jmorris 6 12,955 12-04-2021, 02:26 AM
Last Post: Juergen
