Micro$oft Team$ for aarch64
Hi, if you are interested in get Micro$oft Team$ over your pinebook pro, here is binaries https://privacyshark.zero-credibility.ne...pkg.tar.xz
Github project page is on https://github.com/IsmaelMartinez/teams-for-linux
Original source is on https://forum.manjaro.org/t/manjaro-and-...are/130103
There's a thread about that repo in here as well :)
https://forum.pine64.org/showthread.php?tid=9452
Also, if you don't want to trust binaries, here's the modified PKGBUILD: https://gitlab.com/ohfp/pinebookpro-thin...-for-linux
(04-09-2020, 01:06 PM)erchache2000 Wrote: Hi, if you are interested in get Micro$oft Team$ over your pinebook pro, here is binaries https://privacyshark.zero-credibility.ne...pkg.tar.xz
Hi.
How do I install Teams exactly. I have copied the binaries and the rest into the top folders by that name and created a sym-link in /usr/bin. However the file was not really accepted as a executable at all.
I am using postmarketOS. I saw the discussion in the Manjaro ARM forum and will try that later.
Might be more complex in your case; the binaries are meant for manjaro/arch-systems, so many things could be the issue here (different dependencies, library issues like musl vs. glibc). Do you get a specific error, especially when running it directly (at /opt/teams-for-linux/teams-for-linux in the package)?
It might be worth trying to take a look at the PKGBUILD at https://gitlab.com/ohfp/pinebookpro-thin...-for-linux and see if you you can adapt it for PostmarketOS and with this build it from source – PostmarketOS is, to my knowledge, Alpine-based and thus works with APKBUILDs, which are very similar in structure to PKGBUILDs.
To find out about these dependencies you can run the following command:
ldd <binary>
  slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) mara 41 72,200 03-18-2023, 04:39 AM
  Signal Desktop Builds for Manjaro aarch64 ninefathom 25 51,099 10-23-2020, 02:19 PM
Last Post: llsf
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 16,901 09-29-2020, 07:55 AM
Last Post: hmuller
  Is there a VOIP client compatible with aarch64? mjc 4 8,925 09-18-2020, 04:03 PM
Last Post: mjc
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 65,227 09-06-2020, 08:20 AM
Last Post: pine76
  Slackware (aarch64) on the Pinebook Pro wowbaggerHU 7 14,992 03-12-2020, 08:29 PM
  Luajit in the AUR, loss of aarch64 support tophneal 0 3,082 02-12-2020, 12:25 PM
  gcc-aarch64-linux-gnu on Debian armhf? chihiro 1 4,616 01-05-2020, 08:23 AM
Last Post: ElektromAn
